Help Needed Setting Up Network on Windows XP - Network Help Guys
  • Thread starter Thread starter WaR
    Network
Setting up a network between two Windows XP computers can present challenges, particularly with permissions and visibility issues. The user successfully created a workgroup and can see both computers on the main desktop but encounters permission errors when trying to access the laptop. The laptop, in turn, cannot see the desktop or any other computers in the workgroup, indicating a potential sharing or configuration issue. The user aims to share the entire C drive from the desktop to the laptop but is blocked by permission settings. To resolve these issues, it's suggested to ensure that sharing is properly configured on both machines, including setting up shared folders. Additionally, if the user wishes to dismantle the network setup without affecting their internet connection, they can look into the network settings on both computers to remove the network configuration. The user expresses gratitude for the availability of System Restore points as a fallback option.
WaR
This is the first time I'm trying to set up a Network, I'm using Windows XP on both this one and the Wireless Laptop (yes I know Microsoft is a pain) but I can't do it. Anyone want to help?
This is what I have so far, I set up a network with the wizard on the main computer, gave the workgroup a name and I did the same thing to the Laptop, gave it the same workgroup name and everything.
Now, when I go to the main computer and click on "Show workgroup computers" I can see both computers, but when I try to click on the laptop icon it doesn't let me saying that I need permission...
It gets worse, if I go to the laptop I can't even see the 2 computers on the "view workgroup computers" option, it says I have no permission and to go see the administrator for help... $%&#! I am the damn administrator ! :(
And another thing, I am simply trying to share the entire C drive from the desktop so that I can access it from my laptop. I don't want to share anything from the laptop. And by the way, I am using a router and it works fine. It has 64 bit encryption.
Who wants to help? :)
Edit: Also, if I change my mind, how can I erase the whole network set up and stop sharing everything without killing my internet conection network?
Computer science news on Phys.org
About this part; after setting up your network you should set up a share. Find a folder you would like to share, right-click it, select 'Sharing and Security', and go through the rest of the procedures which should be fairly intuitive. You just might have some luck after doing all that.
Good luck
Thanks for the reply.
Here is the thing, Even if I share something, (I want to share the whole C drive from my desktop to the laptop) but when I go to my laptop, I can't even access the computers in the work space, it says I have no permission. In fact, I can't even see my workplace computers from my laptop, only from my desktop (main computer) i can do this...
Can you help me clear the whole network thing instead? Like erase it or something, without affecting my wireless internet connection? I don't want that network anymore, where do I go to erase it on both computers? :(
Let me see; I think you may need to share something on the laptop before it will appear when viewing your workgroup computers. Another thought is that I believe your router is sending a signal even when wireless networking is disabled. The laptop would detect the signal but you won't be able to connect until you configure the router for wireless operation. I am not knowledgeable on running multiple networks on the same system so not much help there, I'm afraid. What type of router is it?
I have a Linksys and the internet connection is fine. I have no problem (obviously since I'm here) but what I really want now is to eliminate that network configuration, but nothing to do with my original internet connection.
Thanks anyway, I'm still waiting on some help from anyone here.
Edit: Thank God for System Restore points :)
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
