MHB Solve Equations for Variable dp/dL with Expert Help
  • Thread starter Thread starter samiwarraich
The discussion focuses on solving equations for the variable dp/dL, with emphasis on isolating (dp/dL)^(1/B) before raising both sides to the B power. Users express the need to solve multiple equations for dp/dL and inquire about software options for assistance. Mathematica is suggested as a viable tool, with a specific code example provided for solving one equation. Additionally, the user asks if MATLAB can be used for this purpose and seeks guidance on how to begin. The conversation highlights the need for effective computational tools in solving complex equations.
samiwarraich
Can soView attachment 2339me one help to these equation for variable dp/dL
Mathematics news on Phys.org
Do you need to solve all of these for $dp/dl?$ The second one is straight-forward. For any of the equations with $(dp/dl)^{1/B}$, first isolate $(dp/dl)^{1/B}$ on one side of the equation, and then raise both sides to the $B$ power.
YEs i need both equation to solve for dp/dL.Can you do this for me or tell me any software that can do this kind of operation
As an example, you can give Mathematica the following code, and it will solve the first one for $p'(L)$:
Code:
Solve[q==Pi((1/(2A) (p'[L])^(1/B)(B/(3B+1))((D/2)^((3B+1)/B)-Lambda^((3B+1)/B))-(C/3)((D/2)^3-Lambda^3))),p'[L]]
I tried it on Wolfram Alpha, but it didn't understand the command.
Code:
I have Matlab Installed can it be solved if yes then help me to start with
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
