Help on Permuntation and Combination Question
  • Thread starter Thread starter fluffy91
    Combination
3 replies · 3K views
fluffy91
[SOLVED] Help on Permuntation and Combination Question
After a show ,they decided to divide into two groups of size four and five, to go for a supper in 2 taxis. In how many ways could this be done if george and sally were to be in the same taxi
nCn
nPc
No of ways = (3p3 x 2! + 4p4)+(2p2 x 2! + 5p5) = 160
But answer is 56. How do u get the answer it is so small
Taxi A and B have capacities 4,5 resp.
They both (George, Sally) can be either in Taxi A or B. If they're in taxi A, how many more people do you have to select from 7 remaining and in how many ways? And in the second case (taxi B), how many more do you need from 7? Add them up to get your answer.
You need to find the number of ways of selecting 2 and 3 people from 7. Can you see why? Also, the order in which you select the 2 or 3 doesn't matter. Also, the remaining people would occupy the second taxi. So you only need to consider the taxi in which Sally, George are sitting.
The answer indeed is 56.
Regards,
Sleek.
OK Thanks so it was C instead of P. Question solved
That doesn't sound like you really understand the situation, rather that you learn to insert things into equations :( To distinguish between a Permutation and a Combination, consider if order matters. For the taxis, it doesn't because if ABC get into 1 taxi, its the same as BAC etc etc.
