Help Solving Differential Equations
The discussion focuses on solving the first-order linear differential equation x²dy/dx + xy = x²sin(x). The initial approach incorrectly identified the equation as separable, but it was clarified that the correct standard form is dy/dx + (1/x)y = sin(x). The integrating factor was recalculated as I(x) = x, leading to the multiplication of both sides by this factor to simplify the equation. The solution derived was y = (sin(x))/x - cos(x) + C/x, with encouragement to verify the solution by substituting it back into the original equation. The importance of checking solutions to ensure they satisfy the differential equation was emphasized.
JoshP-hillips
Q1.
x2dy/dx + xy = x2sinx
I believe it is a separable equation (first order linear)
First step is to rewrite into standard form;
dy/dx + (xy)/x2 = (x2sin(x))/x2
Then to calculate the integrating factor I(x);
I(x) = e|(xy)/x2dx = eylnx = elnxy = xy
Then i need to multiply both sides of the d.e. by I(x)
JoshP-hillips said:
Q1.
This part is wrong -- e|(xy)/x2dx. In standard form, your equation is dy/dx + (1/x)y = sin(x). The coefficient of the y term is just 1/x, not y/x. With that correction, what should your integrating factor be?
BTW, this is NOT a precalculus question, so I moved it to the appropriate forum section.
Thanks for the tip, and moving the thread.
Here's what I've done;
NEW standard form (from old one)
dy/dx + (1/x)y = sinx
Integrating factor now becomes
I(x) = e|(1/x)dx = elnx = x
Multiplying both sides of the d.e. by I(x) gives;
x dy/dx + x(1/x)y = x sinx
x dy/dx + y = x sinx
Rewriting as d/dx(I(x)y)
d/dx(xy) = x sinx
Integrating both sides with respect to x
xy = x|sinx
xy = sinx - x cosx
y = (sinx)/x - cosx + C/xHow'd I go?
How'd I go?
Differentiate what you got for y and plug it back into the original equation! That's what a solution to the equation means, after all.
I can't resist looking for a more elementary, simple way, of looking at it to see is there a simple
d(of something) there, although having your more general method which will see you algorithmically through all problems of a given category is no doubt more valuable generally.
So looking at that, x2dy/dx can come from d(x2y)/dx which is x2dy/dx + 2xy which is nearly what you want but the factor 2 spoils it and there is no way to fiddle constants to hammer it to what you want, so try to divide the equation by x and then d(xy)/dx works perfectly and gives the same solution result as yours.
Yes, that's the whole point of an "integrating factor". We want to find a function, u(x), such that multiplying dy/dx+ y/x by it will give a "complete differential". That is, we must have d(uy)/dx= u(dy/dx)+ (du/dx)y= u(dy/dx)+ (u/x)y. The "u(dy/dx)" terms cancel leaving du/dx= u/x. du/u= dx/x; ln(u)= ln(x)+ C, u= cx. Since we only need one such function, take c= 1. Then x(dy/dx+ y/x)= x(dy/dx)+ y= d(xy)/dx= xsin(x).
xy= \int x sin(x)dx. Use integration by parts on the right.
The 'I' character you're using to indicate an integral is very hard to spot, appearing identical to 'l' (lowercase L) and very close to '|' (vertical bar).
Why not write it as d/dx(xy)?
JoshP-hillips said:
d/dx(xy) = x sinx
xy = x|sinx
Why is the bar in there?
JoshP-hillips said:
xy = sinx - x cosx
You tell us. Once you have found a solution to a differential equation, you can (and should) check it by verifying that your solution satisfies the DE.
  • · Replies 25 ·
  • · Replies 44 ·
