Is the Set of Functions from Z to [0,1] Truly Uncountable?
  • Thread starter Thread starter trash
    Proof
The discussion centers on the proof that the set of functions from Z to [0,1] is uncountable. Initially, there is confusion regarding the proof's construction of a function that supposedly differs from all functions in a countable list. Participants clarify that the original proof incorrectly defines the function's domain and suggest a more accurate construction. The conversation shifts to the correct interpretation of the proposition, which is about functions from [0,1] to Z, leading to further refinements of the function definitions. Ultimately, the participants acknowledge the need for careful consideration of the function's range and domain in their proofs.
trash
I'm reading about countable and uncountable sets, I found the following statement: "The set of the functions from \mathbb{Z} to [0,1] is uncountable" with the following proof: "To see that, suppose the set countable having the list \{f_1,f_2,\dots\} and define f(x) = f_n(1/n) if x=1/n and f(x)=0 if x\neq 1/n for any n".
Could someone explain this proof further?. It seems to me that he is trying to construct a function that is different from every f_i, but I don't see how the new function is necessarily different from every f_i, can't we have the possibility that all the functions have the same values at 1/n for every n but they are different for other values?.
The proof doesn't make any sense. The function ##f## being constructed does not even appear to be defined on the correct domain, ##\mathbb{Z}##.
Try the following instead. Suppose that we have an enumeration ##\{f_1, f_2, \ldots\}##. We now construct ##f : \mathbb{Z} \rightarrow [0,1]## that is not in the list.
First, let ##g : \mathbb{Z} \rightarrow \mathbb{Z}^{+}## be any bijection. For each ##n \in \mathbb{Z}##, set ##f(n)## equal to any value in ##[0,1]## other than ##f_{g(n)}(n)##. If we want to be concrete (to avoid invoking the axiom of choice), put
$$f(n) = \begin{cases}
1 & \text{ if }f_{g(n)}(n) = 0 \\
0 & \text{ otherwise} \\
\end{cases}$$
Now given any ##m \in \mathbb{Z}^+##, we see that ##f## cannot equal ##f_m## because it differs from ##f_m## at the point ##n = g^{-1}(m)##.
Likes 1 person
Thanks a lot.
But that was my mistake. The proposition is about the set of functions from [0,1] to \mathbb{Z}
trash said:
Thanks a lot.
OK, the proof is still incorrect as stated. It would be OK if it said
##f(x) = \text{ any value except } f_n(1/n)## if ##x=1/n##
Perhaps for concreteness, something like
##f(x) = f_n(1/n) + 1## if ##x=1/n##
Likes 1 person
Assuming you know [0, 1] is uncountable:
f_a(a) = 1 \ and \ f_a(x) = 0 \ otherwise
Defines an uncountable set of functions: one for each a in [0, 1]
Likes 1 person
Thanks a lot, now that makes sense.
Still, for the last example if f_1(1)=1 wouldn't be f(1)=2 which exceeds the domain?, maybe something like f(x)=[f_n(1/n)]/2 would work better?.
I thought you wanted to map from ##[0,1]## to ##\mathbb{Z}##. So the value of ##f(x)## can be as big as we like, but you can't divide by 2, because the result may not be an integer.
Likes 1 person
Yes, you're right. I'm sorry, I read it too fast and didn't think it through :frown:
