help whit problem of college admission exam
The discussion revolves around a physics problem related to forces acting on a mass suspended in an elevator, specifically involving the concepts of tension, weight, and acceleration. Participants are analyzing the equations of motion and the forces involved, particularly in the context of an elevator moving upward with a mass attached to a spring.
  • Participants discuss the correct formulation of the force equations, questioning the notation used for acceleration and the implications of the elevator's motion on the mass. There is a focus on the relationship between the forces acting on the mass and the acceleration of the elevator, with some participants suggesting that the acceleration of the mass may not be directly equated to that of the elevator.
The discussion is active, with participants providing insights and questioning the assumptions made about the system. Some guidance has been offered regarding the force equations, and there is an exploration of the implications of varying gravitational acceleration. Multiple interpretations of the problem are being considered, particularly regarding the relationship between the mass and the elevator's motion.
Participants note the lack of clarity regarding the velocity of the elevator and the assumptions about the mass's acceleration. There is also mention of the variability of gravitational acceleration in different locations, which may affect the calculations.
Camilo08642
If we hang an 11 kg object from the ceiling of an elevator using a spring with a spring constant of 650 N/m, what will be the elongation of the spring in centimeters when the elevator is moving upward while decelerating at a rate of 3.3 m/s²
Σf=m*a
Fe= Δx*k
w= G*m
Σf=m*a
Fe-w=m*-a is this correct?
Camilo08642 said:
Σf=m*a
Certainly, ##\sum F = ma##
Next, on the left hand side you are expressing the sum of the forces as the supporting force from the elevator ##F_e## directed upward (positive) and the weight ##w## of the object directed downward (negative).
So far, so good.
On the right hand side you are expressing ##m \times a## as ##m \times -a##. That is rather unfortunate notation. You would have us believe that ##ma = -ma##.
How about: ##F_e - w = ma## along with ##a=-3.3 \ \text{m}/\text{s}^2##
Can you solve for ##F_e##?
I think that one needs to be careful here with the vectors. Assuming the convention "up" is positive, "down "is negative,
  1. Gravity is down: ##~\mathbf F_g=mg~(-\mathbf{\hat y})##.
  2. We are told that the spring is elongated, so the elastic force is "up": ##~\mathbf F_e=F_e~(+\mathbf{\hat y})##.
  3. We are told that the elevator is moving up with decreasing speed so its acceleration is down. What about the acceleration of the mass hanging from the spring? If we match its acceleration with that of the elevator and write ##~m\mathbf a=ma~(-\mathbf{\hat y})##.
Putting this together gives $$\begin{align} & \mathbf F_e+\mathbf F_g=m\mathbf a \nonumber \\ & F_e~(+\mathbf{\hat y})+mg~(-\mathbf{\hat y})=ma~(-\mathbf{\hat y})\nonumber \\
& F_e-mg=-ma. \nonumber
\end{align}$$ Note that the last equation can be used to find the elongation of the spring when the acceleration of the mass matches that of the elevator.
So far, so good.
thanks for the answer then the answer would be Δx= (M*(G-a))/k= 11.01 cm
The answer seems correct. Though it has too many significant figures. How accurately do you know ##M##, ##k##, ##a## and local ##g##?
It appears that you have used ##g## = 9.80665 m/sec2. However, local ##g## will vary significantly from that standard figure.
https://en.wikipedia.org/wiki/Gravity_of_Earth said:
Gravity on the Earth's surface varies by around 0.7%, from 9.7639 m/s2 on the Nevado Huascarán mountain in Peru to 9.8337 m/s2 at the surface of the Arctic Ocean.[6] In large cities, it ranges from 9.7806 m/s2 [7] in Kuala Lumpur, Mexico City, and Singapore to 9.825 m/s2 in Oslo and Helsinki.
I am troubled by the proposed solution of this problem. We are told that
  • the spring is elongated
  • the elevator is moving up with some undefined velocity ##v##
  • the acceleration of the elevator, not the mass, is 3.3 m/s2 down
So far, so good. What is the justification for equating the acceleration of the elevator with the acceleration of the mass? That would be appropriate if the mass were rigidly attached to the elevator but is not the case here.
Let's consider a plausible scenario that fulfills all of the above pieces of information and see where it leads us. We have an elevator that moves initially at constant velocity ##v## up. The hanging mass is at equilibrium and the elongation of the spring from its relaxed length is ##y_0=\dfrac{mg}{k}.~## At ##t=0## the elevator starts decelerating at 3.3 m/s2 as it nears its destination. At that time the mass will start simple harmonic motion. Its displacement from the equilibrium position, subject to the initial conditions, will be $$y(t)=\frac{v}{\omega}\sin(\omega t)~~~~\left(\omega=\sqrt{\frac{k}{m}}\right).$$ Thus, at ##t=0## the elongation of the spring is $$\Delta L=\frac{mg}{k}= \frac{(11\times 9.8)~\text{N}}{650~\text{N/m}}=16.6~\text{cm}.$$ This answer follows from and is consistent with what is given. If this answer is not what the author of the problem intended, then additional information should have been provided.
  • · Replies 17 ·
  • · Replies 66 ·
