Help with a Trigonometric identity
The discussion revolves around proving the trigonometric identity (sin x + sin 2x + sin 4x) / (cos x + cos 2x + cos 4x) = tan 2x. Participants express skepticism about the validity of the identity, noting that certain values make the right side undefined while the left side remains defined. They emphasize the importance of interpreting the problem correctly, suggesting it should be approached as proving an identity rather than solving an equation. Various strategies are proposed, including manipulating both sides and using known trigonometric identities, but consensus on the identity's validity remains elusive. The conversation highlights the complexities involved in verifying trigonometric identities and the potential for errors in the original problem statement.
questionn
Help with a Trigonometric identity...
sin 2x = 2sinxcosx; cos 2x = cos^2x - sin^2x
solving left side,
=[sin x + sin 2x + sin (2x + 2x)]/[cos x + cos 2x + cos (2x+2x)]
=[sin x + sin 2x + 4 sin x*cos^3 x - 4 sin^3 x * cos x] / [cos x + cos 2x + 1 - 6 sin^2 x * cos^2 x]
Cannot go beyond this!
solving right side,
=2 sin x cos x/(cos^2 x - sin^2 x)
=sin 2x/cos 2x
I don't even think that identity holds. Try x=pi/4, pi/6. It doesn't add up.
What exactly is the "problem statement"? You give an expression. What do want to do with it?
He wants to show how the left-hand side of the equation can be reduced to the right hand side. It's an O-level type of proving trigo identities question.
This is one of those messed up identities. As Defennnder already pointed out, there are values that make the right side undefined, that clearly don't make the left side undefined. Its not a true identities. Many textbooks for some reason do this...
And how do you know? Did questionn tell you personally or is that just your opinion. The fact that it is NOT an identity makes me wonder.
Well, that's the best intepretation I can give it. The equal sign is a big hint though. More importantly the "strategy" used to solve this type of problem is to either start with the LHS and reduce it to the RHS or start with RHS then reduce to LHS is evident in his post. The thread title also hints at this. But if he didn't make any typo error, then perhaps the question should be interpreted to mean "Prove the trigo identity, if possible"
Why are you assuming it couldn't be "solve this equation"?
Yeah I guess you may be right. That's probably what it could mean, since I don't know what else it could be. Just have to wait for the OP to reply.
sin4x = 2sin2xcos2x
thats the way i was taught to do it
Usually the factor formulae are helpful when you have things like sinP+sinQ
The topic of the title is Help with a Trigonometric identity... Why would it become a solve the equation?
I'm also going to assume it's a trig identity, since that's the title of this thread, not "help me solve this trig equation." If you inspect the graph of each function, they're sort of close together between about -pi/4 and pi/4. But, clearly, the graphs are not the same. (OP, that's one strategy to see if it is an identity.)
I know I've seen a trig identity very similar to that problem. If I had more time, I'd play a little and see if I couldn't come up with one.
Okay, I worked it backwards a bit
(I know "you're not allowed to do this", but I was trying to see what the typo might have been.)
multiply the right side by the denominator.
tan2x (cosx + cos2x + cos4x)
now, the tan2x times cos2x takes care of the sin2x term on the left hand side of the equation.
Subtract the sin2x from both sides to see what we have left.
Left: sinx + sin4x
Right: tan2x(cosx+cos4x)
Right: tan2x * cosx + tan2x*cos4x
I'll look at the 2nd term first:
tan2x is tan(4x/2) - use a half angle formula.
[(1-cos4x)/sin4x]*cos4x
oh crud, never mind; I wanted to badly to see 1 - cos^2 4x in that numerator, which would reduce that 2nd term to sin4x. Close, but no cigar. However, that hinted that there may be something relatively close to what the OP's original problem is... My kids are waiting in the car else I'd spend a couple more minutes on it.
It might be worthwhile to attempt to start with tan2x written as tan(4x/2) and use the half angle identity = (1-cos4x)/sin4x then fiddle around with it to introduce some other terms.
  • · Replies 18 ·
