Help with Derivative Homework: f(x)=2x+4/√x
  • Thread starter Thread starter Krypto78
    Derivative
The discussion revolves around evaluating the function f(x) = (2x + 4)/√x and its derivative at x = 0.5. Participants are exploring the correct interpretation of the function and the steps involved in finding its derivative.
  • Mixed
  • Participants are attempting to clarify the function's expression and its simplification. There is discussion about the correct application of exponent rules and the differentiation process.
Guidance has been offered regarding the simplification of the function and the differentiation process. Participants are actively engaging in checking each other's work and clarifying misunderstandings, with some exploring different interpretations of the derivative.
There are indications of confusion regarding the notation and simplification of the function, as well as the rules of differentiation. Participants are encouraged to provide step-by-step reasoning without being given direct solutions.
Krypto78
Given the equation f(x) = 2x+4/√x evaluate:
(1) f(0.5)
(2) f '(0.5)
(1) is simply to substitute the value 0.5 into the equation
(2) however i am assuming is to find the derivative of the equation
This is where i get stuck. Its so basic i know but i always seem to struggle with the simple things.
this is where I am at
f(x) = 2x+4/√x
= 2x/√x + 4/√x
The reciprocal of√x is x^1/2 so I am assuming the 2x/√x is 2x(x)^-0.5 and this is how far i get on this part of the equation.
The 4/√x I am sure = 4x^-0.5 and using the 'direct rule' becomes:-
(-0.5)(4)x^-0.5 - 1
converting to root from:-
-2x^-2/3
from there i get lost.
I would greatly appreciate a step by step solution.
Thanks guys
You wrote f(x) = 2x + 4/sqrt(x), which would equal
[tex]f(x) = 2x + \frac{4}{\sqrt{x}}[/tex]
under the standard rules of operator precedence. However, based on what you subsequently wrote, I am guessing the function is actually
[tex]f(x) = \frac{2x + 4}{\sqrt{x}}[/tex]
which, if you wanted to write it "in line", would be f(x) = (2x + 4)/sqrt(x) [note the parentheses]. This can be simplified as
[tex]f(x) = \frac{2x}{\sqrt{x}} + \frac{4}{\sqrt{x}} = 2\sqrt{x} + \frac{4}{\sqrt{x}}[/tex]
Now, what is this in terms of powers of x?
ill have a go
2x^0.5 + 4x^-0.5
am i on the right path?
Krypto78 said:
ill have a go
2x^0.5 + 4x^-0.5
Yes, that's right. So what do you get if you differentiate this?
As others have noted already, the right side needs to be written as (2x + 4)/√x.
Krypto78 said:
(1) f(0.5)
(2) f '(0.5)
f(x) = 2x+4/√x
= 2x/√x + 4/√x
No, the reciprocal of √x is NOT "x^1/2". The reciprocal of √x is 1/√x, or x^(-1/2). √x and x^(1/2) - note the parentheses) are two ways of writing the same thing.
(-0.5)(4)x^-0.5 - 1
Please use parentheses around your exponents, like so:
(-0.5)(4)x^(-0.5 - 1)
-2x^-2/3
and here, too.
-2x^(-2/3)
That's not the way it works here at Physics Forums. The rules don't permit us to provide you with a step-by-step solution, but we're happy to guide you as you do the work.
Thanks for the reply guys.
Totally understand Mark, thanks for your input:)
jbunniii can you go back 1 step. You simplified 2x/√x to be 2√x. Can i ask how you got this?
on a side note i am doing a self study course so i am my own tutor at present. I really want to get a handle on this so please bare with me.
Thanks
If jbunniii will forgive me for jumping in here there are two ways to do that:
first, note that [itex]x= (\sqrt{x})^2= (\sqrt{x})(\sqrt{x})[/itex] so that
[tex]\frac{x}{\sqrt{x}}= \frac{(\sqrt{x})(\sqrt{x})}{\sqrt{x}}= \sqrt{x}[/tex]
or
[tex]x/\sqrt{x}= x^1/x^{1/2}= x^1x^{-1/2}= x^{1- 1/2}= x^{1/2}= \sqrt{x}[/tex]
Thanks
Oh, dear. Another person who wants us to "bare" with him. This forum is getting too wild for me!
Oh boy..."bare".
Is it too late to change that to "bear" :)
Right where were we
2x^(0.5) + 4x^(-0.5)
= (1/2)(2)x^(0.5 -1) + (-1/2)(4)x^(-1/2 - 1)
= x^(-1/2) + -2x^(-2/3)
Am i right so far
Krypto78 said:
Right where were we
Am i right so far
Almost. What is -1/2 - 1? (Hint: it's not -2/3.)
Hmmmmm now i am stumped.I think this is where I am going wrong. Going by the calculator it is -2/3. Is it 2/3( -and- = + thus 1/2 + 1)
i feel like a plonker:(
Better get another calculator...
If you have 1/2 pizza and 1 pizza, that's not the same as 2/3 pizza.
wow it really has been a long day.
ok ok. Round the wrong way.
so its -3/2
with the correction:-
x^(-1/2) + -2x^(-3/2)
x^(-1/2) = 1/√x
2x^(-3/2) this is where I am lost.....
Thanks for the guidance guys
x^(-1/2) = 1/√x
Well, x^(-1/2) - 2x^(-3/2) is a perfectly valid answer. If you don't like negative roots, then use the fact that
[tex]x^{-t} = \frac{1}{x^t}[/tex]
[edit] I just re-read the original post and recalled that it asks for f'(0.5). So you need to plug in x = 0.5, and simplify if desired.
So just to finish off, removing the negative roots would =
1/√x - 2/x^(3/2) ?
1/√x - 2/x^(3/2) ?
Looks right to me. Now you need to evaluate this at x = 1/2.
Thank you SO much for your help.
What a great forum :)
Before we close this chapter, can i ask what is the "name" given when removing the negative roots?
Far as I know, there's no name. What jbunniii showed is a property of exponents.
  • · Replies 105 ·
11K
