Help with Derivatives in Mathcad
3 replies · 10K views
czechman45
I know that Mathcad only takes partial derivatives. I set up my equations using this general format:
L:= x(t)
Then, I take the derivative of L with respect to t and get the following:
dL/dt -> d/dt*x(t)
However, when I take the derivative of L with respect to x, I should get 1, but am getting 0.
dL/dx -> 0
I've also tried typing dL/d(x(t)), but the program gets mad at me saying that I'm not using a name. Please help. I need Mathcad to take the derivatives of some big expressions with respect to both time and specific variables.
Thank you.
Hi czechman45, welcome to PF :smile:
L:= x(t)
dL/dt -> d/dt*x(t)
dL/dx -> 0
Thank you.
Since you have defined L without a parameter, as far as Mathcad knows, L is not dependent on any parameter, meaning it is treated as a constant.
To fix it you need to define:
L(t) := x(t)
This explains to Mathcad that L is a function with a parameter, and that x(t) is supposed to be used with this parameter.
@I like Serena
I tried your suggestion. It works for dL/dt, but it still gives me 0 for dL/dx, where I'm supposed to be getting 1. Any other suggestions?
czechman45 said:
@I like Serena
I'm guessing a bit, since I don't know what your large expressions look like.
I suspect you need L to be of the form:
L(t,x) := x
Now you can take d/dt from L(t,x(t)) and you can take d/dx from L(t,x).
The first derivative would be a total derivative, while the second is a partial derivative.
In particular each derivative you want to take requires L to have a parameter with the same name.
