Help with easy Differential Equation
The discussion revolves around solving the differential equation y' = 1 + x + y^2 + xy^2. The user successfully transforms the equation to y = tan(x + x^2/2 + C) but seeks clarification on including the integration constant when checking the solution against the original equation. The conversation shifts to discussing the fundamental existence and uniqueness theorem, emphasizing that if certain conditions are met, a unique solution exists near a given point (x0, y0). The participants clarify that the solution's differentiability and continuity depend on the domain and the absence of vertical asymptotes, particularly when considering the function's behavior around specific values of x. Overall, the user gains insight into the theorem's application and the nature of their solution.
JoshHolloway
Here is the equation:
y\prime=1+x+y^2+xy^2
I have gotten it to this point:
\tan^{-1}(y) = x + \frac{x^{2}}{2} + C
Now I am not sure where to go from here. Am I supposed to take the tangent of both sides like this:
tan(tan^{-1}(y)) = tan(x + \frac{x^{2}}{2} + C)
y = tan(x + \frac{x^{2}}{2} + C)
Is that the solution?
Looks good :smile:
If you're unsure, you can always check your answer by plugging it back in the original DE.
When I am plugging the general solution back into the original eqaution to test it do I include the integration constant? Or do I leave it out? What I mean is do I plug this in:
Or do I plug this in:
y = tan(x + \frac{x^{2}}{2})
You leave it in. But honestly, me suggestion was meant 'in general', I now realize that it might be an annoying task to put this back in and simplify to see if it's correct. Sometimes this is a fairly easy method to check your answer. Anyway: your solution is correct :smile:
Ha Ha. I really went and took your advice and worked the damned thing all the way to the end! I ended up with 1+x=1+x
Thanks for the help.
Hey if you don't mind could you check out the thread I just started in the homework section under the precalculus maths. Thanks.
Another question:
State the regions of the xy-plane in which the conditions of the fundamental existence and uniqueness theorem are satisfied.
I have no idea how to determine this. Could you possibly point me in the correct dirrection. In just a second I will post the theorem if you don't know it.
That's great :biggrin:
I think I already did :wink:
Here is the theorem:
Let F and \frac{\partial F}{\partial y} be continuous functions in some rectangle \alpha < x <\beta ,\ \gamma < y < \delta containing the point (x_{0},y_{0}). Then, in some interval (x-h, x+h) \subset (\alpha, \beta), there is a unique solution to the intial value problem:
y \prime = F(x,y),
y(x_{0})=y(y_{0})
I really don't understand this theorum. Is there any chance you could explain it to me?
I assume delta and gamma are the boundaries for y, and not for x again?
The theorem states that if the required criteria are met, i.e. if F is differentiable and F' continuous (is this necessary?) on a certain area which contains a point (x0,y0), then the differential equation y' = F(x,y) with initial value y(x0) = y0 has a unique solution in the neighbourhood of (x0,y0).
yes, your right.
What do you mean by "in the neighbourhood"? Do you mean just close to that point?
So here is the question:
Is that basically asking on what interval is the solution differentianle and continious?
Yes, that's a typical expression in mathematics. It's always an open set, in general it's an open ball of some dimension with a radius r > 0. In the neighbourhood of a point x0 would mean an interval (x0-e,x0+e) where e > 0.
It means that the solution exists at least at the point x0 and 'very close to it'. Often the solution will be valid on a larger domain.
Yes, and the point (x0,y0) has to be in the interior of this domain.
I understand that about 60 percent of the way. But I don't really know what an open set is.
Am I actually supposed to find the point (x0,y0). I don't really understand that part. I understand that I am supposed to state the domain in which the solution is differentiable and continious. But what does that have to do with some point (x0,y0)?
For an intial value problem, that point (x0,y0) should be given. This also allows you to determine the constant C, hence yielding a unique solution. Your solution isn't unique yet, you have 'infinite solutions', because of that indetermined C.
The 'open' means that for the interval (x0-e,x0+e), the end points aren't in the interval, as opposed to a closed interval [x0-e,x0+e]. The open ball I mentioned is for such neighbourhoods in general, in higher dimensions for example. There you have the point x0 as center and a radius r (or e, as you wish).
My problem does not have an initial condition.
It says state the region in which the theorem is satisfied. So I should just state the interval in which the solution is differentiable and continious?
I believe so, but without the point (x0,y0) given, you cannot check if this region contains the point of course.
I get it. Thanks.
Is the answer ALL X SUCH THAT X DOES NOT EQUAL ZERO?
How do I know when the solution is not differentiable if the C is in the argument and I am not given an initial condition?
I believe x is the argument in your solution y(x).
What do you mean? Aren't I supposed to find the values of x for which the solution is differentiable? Wouldn't that be all values of x except when x is zero (or when it is coterminal with zero)?
I'm sorry, I misread your last post as if you thought 'C is the argument', I missed the "in". You're right, it'll depend on C.
You have something of the form y = tan(f(x,c)). Now, tan(a) is nicely continuous and differentiable unless a is an integer multiple of pi (you have a vertical asymptote there). So you need to check where this f(x,c) = k*pi.
Normally, the 'C' vanishes thanks to your condition of the initial value problem, f(x0) = y0. Apparently, that was given here (which I find a bit odd, since it's a part of the conditions you had to check in the existence theorem).
Cool, cool. I think you have pointed me in the direction I needed. Thanks a lot buddy.
You're welcome :smile:
  • · Replies 40 ·
  • · Replies 21 ·
