Help with Energy unit Joules EASY
5 replies · 5K views
daNAV1GATOR
[SOLVED] Help with Energy unit ... Joules... EASY!
The sun burns up 3.6 x 10[tex]^{9}[/tex] kg of matter each second.
Using the formula E = mc[tex]^{2}[/tex], determine how much energy the
sun releases each second. [Speed of light: 3 x 10[tex]^{8}[/tex] m[tex]/[/tex]s]
. .= (3.6 x 10[tex]^{9}[/tex] kg)(3 x 10[tex]^{8}[/tex] m[tex]/[/tex]s)[tex]^{2}[/tex]
. .= (3.6 x 10[tex]^{9}[/tex] kg)(9 x 10[tex]^{16}[/tex] m[tex]^{2}[/tex][tex]/[/tex]s[tex]^{2}[/tex])
. .= 32.4 x 10[tex]^{25}[/tex] [tex]\frac{kg \cdot m^2}{s^2}[/tex]
Now I'm stumped with what to do with the units... I know it should be Joules per second. But how do I show in my solution that Joules will come out? Joules is N[tex]\cdot[/tex]m!
Do I have to change the kg into N? ... My textbook says that the magnitude of c[tex]^{2}[/tex] is 9 x 10[tex]^{16}[/tex] Joules per kilogram.
Please check my calculations also!
Thank You! :smile:
First hint: How is "Joule" defined?
Second hint: If E = mc[tex]^{2}[/tex] is valid, and you have SI units to the right, then you must obtain SI units on the left hand side as well.
The second hint would not be true if you was working with the natural units in sub-atomic phyiscs, where both c and h-bar = 1 i.e E = m, then one must do a more careful unit analysis.
Hmmm...
well Joule is the unit of work. N*m
Newton x meter
HallsofIvy said:
A Joule is N m and a Newton, N, is kg m/s2. So a Joule is kgm2/s2. That's exactly what you have!
So that's understood? I'll then just add...
. .= 32.4 x 10[tex]^{25}[/tex] Joules
Simple as that?
Yipee! :biggrin:
Are my calculations correct? exponents...
