Help with finding the right resistor
  • Thread starter Thread starter MattG2826811
    Resistor
To reduce a DC 12V to DC 5V, using a voltage regulator like the LM7805 is recommended over a resistor, as it provides a stable output and can handle current requirements effectively. Resistors can limit current and may not be suitable for all applications, especially when load current varies. For higher efficiency and current needs, a switching DC-DC buck converter is suggested. It's important to calculate the power dissipation in the regulator to prevent overheating. Overall, a voltage regulator or buck converter is the best approach for this voltage reduction task.
MattG2826811
so i need to reduce a dc 12v to dc 5v. do you know what type of resistor i should use? also could you please suggest an online calculator or an equation so that i can find the resistance i need in the future.
https://en.wikipedia.org/wiki/Voltage_divider
Note that:
Loading effect
The output voltage of a voltage divider will vary according to the electric current it is supplying to its external electrical load. To obtain a sufficiently stable output voltage, the output current must either be stable or limited to an appropriately small percentage of the divider's input current. Load sensitivity can be decreased by reducing the impedance of the divider, though this increases the divider's quiescent input current and results in higher power consumption (and wasted heat) in the divider. Voltage regulators are often used in lieu of passive voltage dividers when it is necessary to accommodate high or fluctuating load currents.
Applications
Voltage dividers are used for adjusting the level of a signal, for bias of active devices in amplifiers, and for measurement of voltages. A Wheatstone bridge and a multimeter both include voltage dividers. A potentiometer is used as a variable voltage divider in the volume control of many radios.
A voltage regulator like the LM7805 might be a better solution depending on your application.
using a resistor is far from a good way to do it. This is because a resistor or resistive voltage divider as billy_joule suggested will also limit the current and that may be a bad thing for what you are trying to achieve
billy_joule's second suggestion is the best ... use a voltage regulator and ensure it can handle the current your project needs
And yes there are ways to boost current requirements via a regulator
for current requirements up to ~ 0.75A ( 750mA) a 7805 reg is ideal
for higher currents and much more efficient operation use a switching DC-DC buck converter
eg ...
http://www.ebay.com.au/itm/DC-DC-Buck-Converter-4-5-35V-to-1-25-30V-3A-Power-Module-24V-to-9V-12V-to-5V-etc-/171640130013?pt=LH_DefaultDomain_15&hash=item27f68c89dd
it can take a wide input voltage range and has an adjustable output and is capable of 3 Amps
cheers
Dave
Likes billy_joule
I like both previous posts and third the suggestion that you drop the voltage with a voltage regulator.
You need to compute the power dropped in the regulator and make sure it can dissipate the heat (that would be true for a resistor also).
The power is 12-5 = 7V times load current. If 100ma. then that is 0.7 watts. Thermal resistance junction to air (to-220 package) is 65C per watt. so the junction will be 65 * 0.7 = 45C above ambient without a heat sink. Max junction temp is 125C. How hot will the environment be?
Another way to look at it. Say a 50C ambient, that leaves 125C - 50C = 75C. 75C / 65C/W = 1.2 watts 1.2 watts/7V = ~160ma. Above that you need a heat sink.
eg ...
cheers
Dave
Note that:
thanks for the tip i think i will use the lm7805
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 26 ·
