Help with horizontal velocity
  • Thread starter Thread starter Physicshelp14
    Horizontal Velocity
Ms. Rob's rocket launch problem involves determining another angle that would achieve the same horizontal range as a 45-degree launch, ignoring air resistance. The discussion highlights the significance of the 45-degree angle, which maximizes range in projectile motion. Participants suggest using trigonometry to find horizontal and vertical velocity components, emphasizing the importance of understanding basic physics concepts. There is a call for more effort in problem-solving before seeking help, as well as a reminder that conceptual physics should provide relevant results. The conversation underscores the need for foundational knowledge in physics and trigonometry to tackle such problems effectively.
Physicshelp14
Help pleasezz with horizontal velocity
Ms. Rob launches a rocket from the school roof at an angle of 45 degrees and observes it's horizontal range. What other angle could she launch the rocket so that it lands in the same spot, ignoring air resistance?
V=d/t
D=v/t
D=1/2gt^2
V=gt
A^2+b^2+c^2
I just can't get it at all I'm getting really frustrated and it's due Friday! :cry::frown:
What is special about the angle of 45deg when it comes to the range?
You can find the horizontal and vertical components of velocity from trigonometry.
recall: sin(45)=cos(45)=1/√2
You can work out the equations of motion by sketching velocity-time graphs for the components.
Please make more of an attempt at problems before posting - there is some very strict moderation going on here at the mo and you have to show some little effort beyond saying "I have no idea". You do have some ideas - you must have spent at least a year in physics class learning how to solve problems in general: do try to apply that knowledge.
Thanks
Thanks for the help I'm kinda still in Conceptual physics 1 and I don't know about trigonometry yet. Is their a simpler way? I just started science this year...thanks AGIAN
You can always draw the triangle and measure - but since this is conceptual physics, you have had a result in your notes about what to do. There's something special about the range at 45degs.
Note: If you know trigonometry anyway - do use it.
