Help with logarithms and graphs
  • Thread starter Thread starter shinto1
    Graphs Logarithms
The discussion focuses on determining equations for various graph types involving logarithmic and semi-logarithmic transformations. Participants analyze how to derive equations from given points on different graph formats, including rectilinear, log-log, and semi-log graphs. Confusion arises around interpreting the logarithmic transformations, particularly in the context of the equations provided. The importance of understanding the relationships between the points and their respective graph types is emphasized, as it affects the resulting equations. Clarification on the implementation of logarithmic functions in these contexts is sought to aid in solving the problems effectively.
shinto1
1. Determine the equation y=f(x) for each of the following cases in simplest form. All of the plots are straight lines and all coordinates are indicated with abscissa first, ordinate second (x,y).
-log y versus log x on a rectilinear graph passes through (5,7) and (2,3)
-(y-2)^2 versus x on a log-log graph passes through (1,2) and (3,4)
-√y versus x on a semi-log graph passes through (3,2) and (6,4)
2. Homework Equations
-Power Equation : y = bx^m
-Linear Equation: y = mx +b
-Exponential Equation: y = be^mx or y = b10^mx (e is base 10)
-Point slope formula: y-y1 = m(x-x1)
3. For the first problem, I found the slope, m, which is 4/3 (or 1.333) and then I used the point slope formula to get y = 1.333x + 0.35. This equation is in a linear format but the thing that confuses me is the "log y versus log x". I used this same process for the other problems but I'm still confused by the "(y-2)^2 versus x on a log-log graph" and
√y versus x on a semi-log graph". I really don't understand how to implement that part of the question into the solution, so any help would be appreciated.
Hint:
On a non-log graph, the coordinates are (10000,10000000) and (100,1000).
Hi shinto1. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
I took that to be a minus sign ("–") in front of your log function, and didn't realize it wasn't until I got to the -√y plotted on semi-log paper!
[PLAIN]https://www.physicsforums.com/Nexus/statusicon/user_online.png (y-2)^2 versus x on a log-log graph passes through (1,2) and (3,4)
[PLAIN]https://www.physicsforums.com/Nexus/statusicon/user_online.png √y versus x on a semi-log graph passes through (3,2) and (6,4)
Do you understand what LawrenceC wrote about the first graph?
If a log-log plot is a straight line, then those same points plotted on an ordinary graph (rectilinear) will likewise be a straight line, but much expanded.
