Help with Matrix Reduction: Q1 & Q2 Answers
  • Thread starter Thread starter ivanyo
    Matrix Reduction
ivanyo
Hi everyone!
I'm in need for some help with Matrix Reduction! I have two questions:
Question 1
Find the inverse of Matrix A by reducing the array (A|I), where
A=
2 4 6
4 5 5
3 1 -3
Question 2
Find all solutions of the following system:
2x1 + 4x2 + x3 - 3x4 - 3x5 = -5
x1 + 2x2 - x3 + 3x4 - 3x5 = -4
-2x3 + 7x4 - x5 = 0
x1 + 2x2 + x4 - x5 = -1The first two images are my attempt at question 1 - I get stuck and can't seem to get the identity matrix on the left. I know the answer (in red) through using a Matrix Calculator.
The last two images are my attempt at question two. I get stuck trying to find x2 and x1 using back substitution. Any suggestions?
*My apologies for the bad handwriting! Imgur is playing up and won't let me rotate the last 3 photos either :(
Image 1 - http://imgur.com/hXHhh
Image 2 - http://tinypic.com/view.php?pic=29kpg5l&s=7
Image 3 - http://tinypic.com/view.php?pic=9zrkex&s=7
Image 4 - http://tinypic.com/view.php?pic=33cxfuh&s=7Thanks for any help in advanced!
Bump! Need help asap!
For the 2nd one, you are going to have one free variable, so let x2 = t. Solve for x1 from that equation. With one free variable, the solution set is not a single point - it's all points on some line in R5.
When you're done, check that your solution satisfies the original system of equations. If so, then you're done.
I didn't look at the 1st problem very closely, but at this level of mathematics you should pretty much never write a fraction as a mixed number. For example, 5/3 is good but 1 2/3 is not good - it makes any further calculations more difficult.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
