Help with Nitromethane for RC Model Car
  • Thread starter Thread starter Rotormaster
To produce flames from the exhaust of a .28 cu in (4.6cc) 2-stroke RC model car engine, the exhaust temperature may not be high enough to ignite unburned fuel. The current fuel mix consists of 20% nitromethane, 16% oil, and methanol, which might not be optimal for achieving visible flames. A glow plug or spark plug that can be activated in the exhaust pipe could help, but direct application of a flame did not yield results. Further adjustments to the fuel mixture or exhaust setup may be necessary to achieve the desired effect. Additional experimentation and modifications are encouraged for better outcomes.
Rotormaster
Hey guys. I am new to the forum and am not a physicist or engineer. I have an RC model car and I am wondering how I can get the exhaust to produce flames. the engine is a .28 cu in (4.6cc) 2-stroke, no spark plug it uses a glow plug, it runs on a fuel mix of 20% nitro, around 16% oil and the rest methanol, normal engine temps are around 250 degrees celsius. If you need more info just ask.
could it be that exhaust temps are not high enough to re combust unburned fuel? or the type of fuel?
Any help will be appreciated, cheers.
You need a spark or glow plug (that can be switched on/off) in the exhaust pipe.
No I don't think this is it either because I tried applying a naked flame from a lighter directly to the exhaust outlet, I did this and tried from the bottom to the top of the rev range and still nada! any other Ideas?
