Help with question mass/displacement
  • Thread starter Thread starter djames1009
The problem involves a particle of mass 2 kg subjected to a drag force, with the goal of finding an expression for displacement x(t) and evaluating it at t=4 seconds. The context is within the subject area of dynamics and differential equations.
  • Participants discuss the setup of the problem, including the use of initial conditions and the formulation of a separable ordinary differential equation. There is exploration of integration techniques and the implications of constants in the equations.
Some participants have provided insights into the integration process and the handling of initial conditions. There is recognition of the complexity of the problem, with some questioning whether the level of difficulty is appropriate for their current understanding. Multiple interpretations of the integration steps are being explored, particularly regarding the constants involved.
Participants note the importance of correctly applying the mass value in the equations and the distinction between indefinite and definite integrals in their calculations. There is also mention of homework constraints regarding the methods allowed for solving the problem.
djames1009
A particle of mass 2kg is subject to a drag force from the air: F(v)= -0.5v^2. The initial displacement of the mass is zero and the initial speed is 1ms. Find an expression for x(t) and hence work out x(4)
Ive got this question in one of my textbooks and can't seem to get it to work, could anybody help me with the answer at all?
I have tried a few things, and i know i have to integrate, but i am getting a bit confused :s. If somebody could show me how its done, then i can look back at it and understand all the steps, as there is other questions like this i plan to eventually answer.
Thanks a lot :D
Or if anybody could just help me start off that would be great also!
From the initial conditions we know that:
x(0)=0 m
v(0)=1 m/s
I'm going to keep using the notations v(t) and x(t) to try to remind you that v and x are functions of t, which is very important when doing calculus.
For a constant mass:
F(v(t))=ma=m\frac{dv(t)}{dt}=-0.5v(t)^2
So:
\frac{dv(t)}{dt}=\frac{-0.5v(t)^2}{m}=\frac{-v(t)^2}{4}
Erm... which is a separable ordinary differential equation... this is a lot higher leveled than I thought, is this like a university leveled maths question? You're going to need someone else to confirm the answer since I'm not sure if it was meant to turn out like this lol. Anyway, separating gives:
-\int\frac{1}{v^2}dv=\int\frac{1}{4}dt
Integrating gives:
\frac{1}{v(t)}=\frac{t}{4}+c=\frac{t+4c}{4}
\Rightarrow v(t)=\frac{4}{t+C}
Since, from the second initial condition:
v(0)=\frac{4}{0+C}=1 m/s
Then:
C=4
Giving:
v(t)=\frac{dx(t)}{dt}=\frac{4}{t+4}
Integrating with respect to t:
\int\frac{dx(t)}{dt}dt=\int\frac{4}{t+4}dt
Gives:
x(t)=4ln(t+4)+b
Since, from the first initial condition:
x(0)=4ln(0+4)+b=0
Then:
b=-4ln(4)
Which gives the final equation for displacement, x(t):
x(t)=4(ln(t+4)-ln(4))=4ln(\frac{t+4}{4})
And:
x(4)=4ln(\frac{4+4}{4})=4ln(2) m
Okay thanks a lot, i'll post it onto an advanced section and see what other people get aswell, thanks :D
And sorry yeah it does mention about seperating by variables, so this does seem correct. The only thing i have seen is when you have put -v(t)^2/m you have put m as 4, should it be 2 or have i got it wrong ha?
0.5=\frac{1}{2}
So:
a=-0.5v(t)^2/m=-\frac{1}{2}\frac{v(t)^2}{m}
Ah i see my fault ha XD
Hi I've just realized at this point the limits should be,
for -\int\frac{1}{v^2}dv should be V and 1.
and for -\int\frac{1}{4}dt should be t and 0.
Could you give me any help here?:smile:
What I did there is called an indefinite integral. There are no limits, and is also the reason why I had to add a constant to the answer (I had to add one to both sides of the equation but I shifted both constants to one side to give the single c; another subtlety you might have noticed was that I converted the 4c into a single big C).
  • · Replies 56 ·
  • · Replies 31 ·
  • · Replies 25 ·
