How Does Rolle's Theorem Apply to Intersecting Planes in Vector Calculus?
  • Thread starter Thread starter monea83
    Theorem
Rolle's Theorem is discussed in the context of intersecting planes defined by a one-parameter family of equations involving normal vectors and base points that depend on the parameter u. The planes intersect in a line, which is described by a specific equation involving the differences of the normal vectors and base points. The application of Rolle's Theorem is questioned, particularly regarding the requirement for equal function values at endpoints, which seems absent in the given context. Clarifications are sought about the notation used, specifically the roles of vectors and scalars in the equations presented. Understanding these concepts is crucial for applying the theorem correctly in vector calculus.
monea83
Given is a one-parameter family of planes, through
x \cdot n(u) + p(u) = 0
with normal vector n and base point p, both depending on the parameter u.
Two planes with parameters u_1 and u_2, with u_1 < u_2, intersect in a line (planes are assumed to be non-parallel). This line also lies in the plane
x \cdot (n(u_1) - n(u_2)) + p(u_1) - p(u_2) = 0
Now, the book I am reading claims that, "by Rolle's theorem, we get:"
x_1 n_1'(v_1) + x_2 n_2'(v_2) + x_3 n_3'(v_3) + p'(v_4) = 0 with u_1 \leq v_i \leq u_2.
However, I don't see how the theorem applies here... for starters, I don't see anything of the form f(a) = f(b), as required by the theorem.
Mathematics news on Phys.org
I'm trying to understand your notation. If n and p are vectors, I supose x is a vector dotted into n, which gives a scalar?? How do you add a scalar to a vector? Is the 0 on the right side a scalar or vector? And you say you have a one parameter family of planes through
What do you mean by that?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
