Help with Sketching curves/Simultaneous equation
  • Thread starter Thread starter TalkOrigin
The discussion revolves around solving simultaneous equations involving the curves y = (x-1)^3 and y = (x-1)(1+x). The user successfully identifies two intersection points (x = 0 and x = 3) but misses the third point (x = 1) due to dividing by (x-1) without recognizing it as a potential solution. Clarification is provided that while dividing by (x-1) is valid for other solutions, it cannot be done when x equals 1, as this results in division by zero. The correct method involves acknowledging x = 1 as a solution before proceeding with the division, ensuring all intersection points are accounted for. Understanding this concept is crucial for accurately solving similar problems in the future.
TalkOrigin
Hi, I'm stuck on what should be an easy problem and I'm not sure where I'm going wrong. I already know the answer (I'm self studying), it's the method for the solution I don't understand. Here's the problem:
a) on the same axes sketch the curves given by $$y= (x-1)^3$$ and
$$y= (x-1)(1+x)$$
b) find the coordinates of the points of intersection
So, I did part a, and I thought i did part b, but I only got 1 of 3 possible solutions.
Anyway, here was my attempt at a solution:
$$ (x-1)^3 = (x-1)(1+x)$$
$$(x-1)^2 = (1+x)$$
Then multiply out the brackets: $$x^2 - 2x + 1 = 1+x$$
Simplify: $$x^2 - 3x = 0$$
Factorise: $$x(x-3) = 0$$
From this I can get 2 values for x (0 and 3) and plug them into the original equations. I know these two are correct, but I'm missing one and I'm pretty sure my method is wrong.
I had a look at the solution (the textbook I have comes with online worked solutions) but I've been staring at it and don't understand it. the solution they give is:
$$(x-1)^3 = (x-1)(x+1)$$
$$(x-1)^3 - (x-1)(x+1) = 0$$
This is the part I don't understand at all:
$$(x-1)[x^2-2x+1-(x+1)] = 0$$
Then $$(x-1)(x^2-3x)=0$$
$$(x-1)(x-3)x = 0$$
$$x = 0, 1, 3$$
Any help on this would be greatly appreciated, thank you.
Yeah, you've done good, but you just missed one of the points. You had this equation:
And then after this, you divided by (x-1) on both sides. This is the correct method to get two of the points. But before you do the division, you must identify the other point. Another way to think of it is - can you always divide by (x-1) ? What are you assuming here?
EDIT - just realized all the working in my reply was wrong. Maybe I'm just having a bad day but I'm not able to get this at all... What am I assuming?!
your reply? did you delete your reply? I don't see it...
Anyway, so to divide by (x-1), what value of x will give you problems?
Yeah I deleted it, I didn't want you to waste your time replying to something I knew was incorrect.
I think I understand now, x cannot be 1 can it? If it is then you're dividing by 0 which means the answer will be undefined, but if x can't be 1 then how does it end up being one of the coordinates? Looking at the equation, I can see that subbing in 1 for x does work, I'm just not sure how I would come to that conclusion methodically. Does the method that I showed in my original post, the one given in the solutions book, make sense to you?
yeah, exactly. You can't divide by (x-1) when x has the value one. And yes, subbing in for x=1 does work, so x=1 must be a solution. You can think of it like this: OK, you've found that x=1 is one solution. So then to find other solutions, it is OK to divide by (x-1) because for other solutions, x must be different from one.
And the solutions book method is correct. It is pretty much the same as your method, they just did it slightly differently. The way they did it, they rearranged things so that they ended up with the three factors. So then at the end they have the nice equation:
(x-1)(x-3)x = 0
Where the three solutions are all in one line. But your method was also correct. It is just that when you got to the step where you divided by (x-1), you should have written "and here, you can see x=1 is one solution" or something like that, and then continued to find the other two solutions.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
