Help with solution group of a Homogeneous system
The discussion revolves around the relationship between the solution sets of two homogeneous systems of equations, specifically whether the solution group of the system A3X = 0 is equal to that of AX = 0. The original poster seeks clarification and proof regarding this relationship.
  • Participants explore the implications of the original poster's question, discussing the validity of their attempts and counterexamples. There is a focus on understanding the conditions under which A-1 exists and the relationship between the two systems of equations.
The discussion is active, with participants providing insights and questioning the assumptions made by the original poster. Some guidance has been offered regarding the computation of A3 and the implications of the solution sets, but there is no explicit consensus on the correctness of the arguments presented.
Participants note the potential confusion regarding the existence of the inverse of matrix A and the implications of the computations involved in determining the solution sets.
afik
Summary:: need help with solution group of Homogeneous system
Is the solution group of the system A^3X = 0
, Is equal to the solution group of the system AX = 0
If this is true you will prove it, if not give a counterexample.
thank you.
Have you tried anything?
I tried but I failed..
The matrix A ∈ Mn (R)
Well, you can show us your work, it could be a good point to start
second attempt:
Doesn't the first attempt exactly answer your question?
The second attempt has the problem that ##A^{-1}## doesn't exist for ##A \in M_n(\mathbb{R})##.
I do not know if I do it right in the first attempt...
Why in the second attempt A^-1 does not exist?
Well, literally, your question is:
"Is the solution group of the system ##A^3 x = 0## equal to the solution group of the system ##Ax = 0##?"
And you literally wrote:
"system group of ##A x = 0 ## are not equal to system group of ##A^3 x = 0##"
So doesn't that answer your question?
For the ##A^{-1}## question is easy, the example you use, let ##A = \begin{pmatrix}0&1\\0&0\end{pmatrix}## then
$$A \in M_2(\mathbb{R}), \qquad \nexists A^{-1}$$
I wrote it down, but I do not know if my counter-argument is true there, or if I am wrong.
Ah well, then that's a completely different thing. What in that argument do you think can be wrong?
If I know what can be wrong I finish the homework... I don't know :(
Ok, so what things in your argument are you absolutely sure are correct?
If Ax= 0 then certainly A^3x=A^2(Ax)= A^2(0)= 0 for A any linear operator. So the solution set of A is a subset of the solution set of A^3. The question is "are there x that satisfy A^3x= 0 but not Ax= 0?
Can you help me more, I need it for tomorrow :(
Yes, that's correct. But in your prove you essentially did 3 things:
1. Calculate the solutions of ##Ax=0##
2. Calculate the matrix ##A^3##
3. Calculate the solutions of ##A^3 x = 0##
What of these steps do you think may be wrong? And what of these steps you are 100% sure are right?
I think that 1 and 3 are correct and 2 is wrong.
Well, so let's take a closer look at the computation of ##A^3##, do you have the intermediate steps?
No, I don't have any idea.
Have you studied how matrices are multiplied? If you know that to compute ##A^3## is just computing first
$$A^2 = A \cdot A$$
and then
$$A^3 = A \cdot A^2$$
