A Help with the Proof of an Operator Identity
The discussion centers on proving the operator identity used in the Mori projector operator formalism for Generalized Langevin Equations, specifically the expression involving the Liouville operator L and the projection operator P. The author expresses uncertainty about the assumption that L and P commute, which is crucial for the derivation. They outline their steps in the proof but recognize that their reliance on this commutation may be flawed. Another contributor clarifies that the identity can be shown without assuming commutation by demonstrating that both sides satisfy the same differential equation and initial conditions. This insight suggests that the proof is valid without needing to justify the commutation of L and P.
Opus_723
I'm trying to come up with a proof of the operator identity typically used in the Mori projector operator formalism for Generalized Langevin Equations,
e^{tL} = e^{t(1-P)L}+\int_{0}^{t}dse^{(t-s)L}PLe^{s(1-P)L},
where L is the Liouville operator and P is a projection operator that projects onto a finite subset of Hilbert space, abstractly defined by
PB = \sum_{j,k}(B,A_j)((A,A)^{-1})_{j,k}A_k
Where A is the set of functions to be projected onto and ( . , . ) denotes an unspecified inner product.
Unfortunately, I'm pretty rusty with operators in general, and although I can write down a "derivation," it relies on an assumption that I can't figure out a justification for. Here is what I did:
e^{tL} = e^{t(1-P)L}+e^{tL}-e^{t(1-P)L}
e^{tL} = e^{t(1-P)L}+e^{tL}(1-e^{-tPL})
e^{tL} = e^{t(1-P)L}+e^{tL}(e^{-0*PL}-e^{-tPL})
e^{tL} = e^{t(1-P)L}+e^{tL}(-e^{-tPL})\bigg|_0 ^t
e^{tL} = e^{t(1-P)L}+e^{tL}\int_{0}^{t}\frac{d}{ds}(-e^{-sPL})
e^{tL} = e^{t(1-P)L}+e^{tL}\int_{0}^{t}PLe^{-sPL}
e^{tL} = e^{t(1-P)L}+e^{tL}\int_{0}^{t}PLe^{-sL+s(1-P)L}
e^{tL} = e^{t(1-P)L}+\int_{0}^{t}e^{(t-s)L}PLe^{s(1-P)L}
Notice, however, that throughout this process I liberally assumed, in many steps, that the projection operator P and the Liouville operator L *commute*, mostly by blithely using the typical properties of the exponential as if the operators were numbers, but also in the last step more explicitly. So I see 3 options:
1) L and P are guaranteed to commute for some reason that's not obvious to me.
2) This is a bad way to prove the identity and if I did it some other way I wouldn't need them to commute, or maybe I am completely misunderstanding how to manipulate these objects.
3) This assumption is *not* guaranteed, but it *is* actually necessary for the identity to hold even though I haven't seen this assumption stated explicitly anywhere.
My guess is that either 1 or 2 is the correct answer, but I'm not able to puzzle it out. Can anyone with more experience with projection operators help me understand this identity? Thank you for your time.
EDIT: If it helps, I'm following the treatment in Ch. 8 of Nonequilibrium Statistical Mechanics by Robert Zwanzig, although this same identity seems to pop up along with an "it is easy to show that..." in every treatment I can find.
Let's define
$$F(t)=\exp(t L).$$
Then ##F## is defined by the differential equation
$$\mathrm{d}_t F(t)=L F(t)=F(t) L, \quad F(0)=1.$$
The only thing we need to do is to show that also the right-hand side of the equation fulfills the same differential equation and initial condition. The latter is trivial.
Now let's take the derivative wrt. ##t## of the right-hand side, which we call ##\tilde{F}(t)##
$$\mathrm{d}_t \tilde{F}(t)=(1-P)L \exp[t (1-P)L]+P L \exp[t(1-P)L]+L \int_0^t \mathrm{d} s \exp[(t-s)L] P L \exp[s(1-P)L]=L \tilde{F}(t).$$
So indeed ##\tilde{F}## fulfills the differential equation and the initial condition as ##F##. So ##F=\tilde{F}##. Note that I've nowhere used that ##P## and ##L## maybe commute.
I hope, I've not overlooked any detail, because this looks so simple ;-).
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
