Help with torque and equilibrium
  • Thread starter Thread starter mrtheshaggy
    Equilibrium Torque
The discussion revolves around a physics problem involving a uniform meter stick in equilibrium, supported by a wall and a cord at a 15-degree angle. The key challenge is to determine the minimum distance x from the wall at which a block, equal in weight to the meter stick, can be suspended without causing the stick to lose equilibrium. Participants suggest using equations for tension and forces, including static friction, to analyze the system's stability. The equations provided include the relationship between tension, gravitational force, and frictional forces, emphasizing the need for clarity in the vertical force balance. The focus remains on achieving a correct understanding of equilibrium conditions for the setup.
mrtheshaggy
Thanks for the many helpful posts/answers I've found through google! I ran into one I can't figure out, any help is much appreciated!...
One end of a uniform meter stick is placed against a vertical wall. The other end is held by a lightweight cord that makes an angle @ with the stick. The coefficient of static friction between the end of the meter stick and the wall is .370.
Let the angle betwewen the cord and the stick be @=15 degrees. A block of the same weight as the meter stick is suspended from the stick, as shown, at a distance x from the wall. What is the minimum value of x for which the stick will remain in equilibrium?
Here is a quick illustration I made... www.theshaggy.com/meter_stick.jpg
I tried setting
sin@*T = m*g*x + m*g*(L/2) ...making tension... T = m*g*(x+L/2)/sin@
so the F_x = u*cos@*T ///u=coefficient of friction
and F_y = m*g*(x+L/2) - T*sin@
the I'd set them equal to each other, which ended up wrong. I think I'm on the right track but can't figure out where I am going wrong.
Equillibrium
Please make the F_y equation clear.Dimensions do not match
The two equations might be as follows:
T*sin@*L=M*g*0.5L+M*g*x
and
2*M*g=T*sin@+u*T*cos@
These two equations are considering the rotational and translational equillibrium of the body
