Help with understanding capacitance
  • Thread starter Thread starter johnnyies
    Capacitance
Capacitors store energy in their plates and release it when a circuit is completed, typically in an exponential manner. Common applications include temporary power sources and filtering in AC circuits, where their impedance varies with frequency. In parallel configurations, capacitors maintain the same voltage, while in series, the voltage differences add up to match the total voltage of the battery. Understanding capacitors is easier when considering their behavior in AC circuits, as they are more effective in those scenarios due to frequency-dependent impedance. The key to utilizing capacitors lies in providing a path for the stored charge to flow.
johnnyies
my book does not fare well in explanations, thus I have a few questions
if the capacitor plates hold energy, how does this energy become released in certain applications? what are some common applications of capacitors?
if the voltage difference in parallel capacitors are the same, why is the voltage difference in series capacitors different? why do they add up to be the overall voltage of the battery?
more questions as I read more about this
sorry if they're stupid questions, book sucks kinda.
Hi johnnyies! :smile:
It's released (not all at once, but exponentially) when the circuit (joining the two plates "the long way round") is completed.
It has to be, or charge would flow between the two capacitors.
… why is the voltage difference in series capacitors different? why do they add up to be the overall voltage of the battery?
For the same reason as for resistances. :smile:
(There's nothing "magic" about capacitors … just think about what the charge does … the total charge is conserved, and it moves if there's a voltage difference :wink:)​
yes, but how do we release that charge from the capacitors?
In a DC circuit the charge stored can only be released if you give the capacitor a path to release it through. For instance you could charge a capacitor using a DC power supply and then disconnect the capacitor and use it as a temporary power source in another circuit.
You might be struggling to understand them because you're focusing on its DC applications, in DC circuits with ideal conditions capacitors have little use. However, capacitors are extremely useful in AC circuits due to the impedance being affected by frequency (in proportion to its capacitance).
In AC circuits its useful to think of capacitors in terms of impedance. Its impedance is higher with lower frequencies (with a frequency of 0 it's open circuit) and its impedance is lower when the frequency is higher (at infinite frequency it's short circuit).
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
