Hermitian Operator in Inner Product
7 replies · 3K views · last reply
Unto
[itex]\int d^{3} \vec{r} ψ_{1} \hat{A} ψ_{2}[/itex] = [itex]\int d^{3} \vec{r} ψ_{2} \hat{A}* ψ_{1}[/itex]
Hermitian operator A, show that this condition is equivalent to requiring [itex]<v|\hat{A}u>[/itex] = [itex]< \hat{A}v|u>[/itex]
I changed the definitions of ψ into their bra-ket forms first of all.
Hints say something about the Identity operator, but I don't have any bra's in my equation, what do I do?
After changing the ψ into their bra-ket forms and substituting, I am stumped. Any pointers please?
I have introduction into adjoint hermitian operators but I cannot see how this would fit into it.
I would write more about what I did, but your equation editor is very difficult to use, is it possible that you could make a code that mirror's the equation editor on Microsoft Word 2007 - 2011?
Please help me, I'm doing this problem WAY ahead of time and I just want to be good at this stuff. Please don't ignore me, just give me a push in the right direction and I promise I will do all the rest and show you what I did.
It would help if you showed what you did rather than just describe it.
Latex takes forever to use... Well here goes:
We are supposed to assume that [itex]ψ_{1}*[/itex] is a wavefunction, so we use a trick to show just that, whilst the conjugate is now something wierd
[itex]ψ_{1}* = < \vec{r}|ψ_{1} >[/itex]
[itex]ψ_{1} = < ψ_{1}|\vec{r} >[/itex]
So subst into
[itex]\int d^{3} \vec{r} < ψ_{1}|\vec{r} > \hat{A} < \vec{r}|ψ_{2} >[/itex] = [itex]\int d^{3} \vec{r} < \vec{r}|ψ_{2} > \hat{A}* < ψ_{1}|\vec{r} >[/itex]
([itex]| \vec{r} > < \vec{r} |[/itex]
Left side can have the r thingy rearranged in terms of identity bra-ket which is 1, so we get:
[itex]< ψ_{1}|\hat{A}|ψ_{2} >[/itex] = [itex]\int d^{3} \vec{r} < \vec{r}|ψ_{2} > \hat{A}* < ψ_{1}|\vec{r} >[/itex]
Right side becomes:
[itex]| ψ_{2}>\hat{A}*< ψ_{1}|[/itex]
Swap around the functions on the right side to get:
[itex]< ψ_{1}|\hat{A}|ψ_{2} >[/itex] = [itex]< ψ_{2}|\hat{A} *|ψ_{1} >[/itex]
Remembering that [itex]\hat{A} = \hat{A}*[/itex] for an hermitian function. Dunno whether this is correct.
Latex is so hard to use, anything easier?
Can you explain how you went from
[tex]\int d^3\vec{r}\,\langle\psi_1\vert\vec{r}\rangle\hat{A}\langle\psi_2\vert\vec{r}\rangle[/tex]to [itex]\langle\psi_1\vert\hat{A}\vert\psi_2\rangle[/itex]?
That's not what I did..
I went from [itex]\int d^{3} \vec{r} < ψ_{1}|\vec{r} > \hat{A} < \vec{r}|ψ_{2} >[/itex] to [itex]< ψ_{1}|\hat{A}|ψ_{2} >[/itex]
I used that identity relation with the bra of the r facing the ket of the r... it equals 1.
Sorry, that was a typo. The thing I don't like is you have the operator sandwiched between the [itex]|\vec{r}\rangle[/itex] and [itex]\langle \vec{r}|[/itex]. It's not clear that you can just then eliminate the pair from the expression. It would be better if you wrote it as follows:
\begin{align*}
\int d^3\vec{r}\, \psi_1^* \hat{A} \psi_2 &= \int d^3\vec{r}\, \psi_1^* (\hat{A} \psi_2) \\
&= \int d^3\vec{r}\, \langle\psi_1 | \,\vec{r}\rangle\langle\vec{r}\, |\, \hat{A}\psi_2\rangle \\
&= \langle \psi_1 |\, \hat{A}\psi_2 \rangle
\end{align*}
Nicely done broslice, I assume I do the same thing for the right side?
EDIT:
Done, thanks a lot, since it's hermitian, the conjugate remains the same as normal and the condition [itex]<v|\hat{A}u>[/itex] = [itex]< \hat{A}v|u>[/itex] is met.
Can you help me on my other topic? Just a point in what to do with the probabilities, thank you in advance.
