Hess' Law Calculation for Reaction A: \Delta H = 121 kJ | Reference Table Used
  • Thread starter Thread starter DB
    Law
The calculation of the enthalpy change (\Delta H) for reaction A, represented as 3CH4 → C3H8 + 2H2, is confirmed to be +121 kJ using Hess' Law. The calculations involved reversing and adjusting two reference equations: B (C + 2H2 → CH4, \Delta H = -74.9 kJ) and C (3C + 4H2 → C3H8, \Delta H = -103.7 kJ). By multiplying equation B by three and reversing it, the correct enthalpy values were summed to arrive at the final result.
  • Understanding of Hess' Law
  • Knowledge of enthalpy changes in chemical reactions
  • Familiarity with stoichiometry
  • Ability to manipulate chemical equations
  • Study Hess' Law applications in thermochemistry
  • Learn how to calculate enthalpy changes using standard enthalpy of formation
  • Explore the concept of reaction reversibility in thermodynamics
  • Investigate the use of reference tables for enthalpy values
Chemistry students, educators, and professionals involved in thermodynamics and reaction energetics will benefit from this discussion, particularly those focused on calculating enthalpy changes using Hess' Law.
DB
I don't have the answer to this, and it's a big question so I'd like to know if I got it right. Thanks
Determine the \Delta H value for reaction A:
A)3CH_4 \rightarrow C_3H_8 + 2H_2
\Delta H=?
Okay so I was given a reference table and used these two equations for Hess' Law:
B)C+2H_2 \rightarrow CH_4
\Delta H= -74.9
C)3C+4H_2 \rightarrow C_3H_8
\Delta H=-103.7
So I knew I the sum of B and C would have to give me A, so in order for the values to cancel properly I had to multiply B by three:
B)3(C+2H_2 \rightarrow CH_4)
3(\Delta H=-74.9)
gives me:
B')3C+6H_2 \rightarrow 3CH_4
\Delta H=-224.7
Then, since propane is on the left side of equation A, I would have to reverse B':
3CH_4 \rightarrow 3C + 6H_2
\Delta H=+224.7
Now I can add them:
3CH_4 +3C - 3C \rightarrow C_3H_8 + 6H_2 - 4H_2
gives:
which is equation A.
So now I must add the change in enthalpy:
\Delta H=+224.7+\Delta H=-103.7
\Delta H=121 kJ for reaction A
is that right?
thanks
yes, it is.
thanks for all the help andrew
10K
13K
27K
22K
  • · Replies 17 ·
