High volt result low amp, why?
  • Context: High School
  • Thread starter Thread starter sleepsleep
    Amp Volt
The discussion revolves around the relationship between voltage, current, and resistance in electrical circuits, particularly addressing the question of why high voltage does not necessarily result in high current. Participants explore concepts related to Ohm's law, resistance, and the behavior of electrons in conductive materials.
  • One participant describes voltage as the result of a difference in electron concentration and questions why high voltage does not lead to high current.
  • Another participant asserts that higher potential difference generally leads to higher current, referencing Ohm's law.
  • A participant challenges the assumption that current is low, asking for clarification on how this conclusion was reached.
  • Some participants discuss the analogy of pushing a book to explain resistance and current flow, suggesting that initial resistance may be higher.
  • Concerns are raised about the relationship between temperature and resistance, with one participant noting that resistance can increase with temperature, affecting current flow.
  • Questions are posed regarding the nature of heat generation due to electron movement and the mechanisms of resistance in materials.
  • One participant discusses the concept of constant power in transformers, highlighting the inverse relationship between voltage and current in different windings.
  • Another participant expresses confusion about using water pipes to transfer electricity, questioning the efficiency and practicality of such a system.
  • Clarifications are made regarding the definitions of voltage, current, and resistance, with some participants attempting to reconcile their understanding of these concepts.
Participants express various viewpoints on the relationship between voltage, current, and resistance, with no consensus reached. Some participants support the idea that higher voltage leads to higher current, while others question this relationship based on different contexts and analogies.
Participants reference Ohm's law and the behavior of materials under different conditions, but there are unresolved questions about the nature of resistance and the effects of temperature on current flow. The discussion also touches on analogies that may not fully capture the complexities of electrical behavior.
This discussion may be of interest to those studying basic electrical concepts, including students learning about circuits, voltage, current, and resistance, as well as individuals curious about the practical applications of these principles.
sleepsleep
hi,
i am quite new to physics, so i hope you guys could tolerate with me :blushing:
from what i read from internet and some chat with people, i know high volt is the result of high different potential (eg. point A got lots of electrons, so point A electrons moves to point B through a "conductor {thing that connects them and allow electrons to flow aroudn}" in order to balance)
http://science.howstuffworks.com/electricity.htm said:
In an electrical circuit, the number of electrons that are moving is called the amperage or the current, and it is measured in amps. The "pressure" pushing the electrons along is called the voltage and is measured in volts.
One amp is the number of electrons moving (1 amp physically means that 6.24 x 10^18 electrons move through a wire every second)
so "more" electrons need to flow from point A to point B if electric potential is high, since more electrons are moving, why the amp is low? shouldn't it be high?
Generally, the higher the potential difference applied across a material, the higher will be the current through that material.
Imagine that you apply a 1V potential difference across some piece of resistive material, and a current of 1A flows.
Now imagine that you apply a 2V potential difference across the same material. Since the applied potential difference doubled, so does the current. The material will now be carrying a 2A current.
This relationship -- the proportionality between potential difference and current -- is called Ohm's law.
- Warren
Why do you think the "amp is low"? Who told you the "amp is low"?
thanks
let say in real world, when we try to push a book on table, the first push would requires more "energy" than the subsequent push (so resistance becomes lower as time goes). so, does something like this happen to electrons when they try to to move from point A through "conductor/resistor" to point B?
There is no electrical analogue to the difference between kinetic and static friction. The same concepts just don't apply.
There is an effect due to temperature, however. In general, the resistance of a material increases with temperature. When you initially apply a potential difference to a material with low resistance, current flows, and the material's temperature and resistance rise. As the resistance rises, the flow of current actually decreases.
- Warren
- Warren
1. is the heat generated due to the movement of electrons? (no movement = no heat, continuous movement = increasing temperature) ?
2. is that the electrons initiate movement? or they are being dragged/sucked by the "lack of electrons" in material B?
3. is low resistance material same as "material that lack of electrons" ?
4. is "resistance" a form of atom / structure (in wire or point B material) that could block the movement of "electron" from point A to point B
or
resistance is a state where (no more or less ) electron could move into the material B from wire (where material B already achieved balance / stable, or it doesn't suck electrons anymore)
When you are dealing with a constant power situation, such as a transformer, the product of current and voltage, VI, is constant (in an ideal transformer) --- low voltage and high current in one winding, and high voltage and low current in another. This is probably the situation that was described to you.
Yes.
They are motivated by the electric field, which is created through the material when you apply an external potential difference.
No. A material that lacks electrons is simply positively charged.
or
There are actually numerous different mechanisms by which resistance is created. The most common is thermal in nature; heat causes atoms to vibrate around their equilibrium positions, causing more frequent collisions with electrons, which on average slows their motion down.
- Warren
thanks chroot for the information provided, i couldn't reply fast coz i need time to digest those information.
one thing i don't understand is, since the movement of electrons could create heat in "wire", why we didn't use (pipe+water) to transfer electricity? :confused: then less heat would be resulted from the movement of electrons?
btw, would the movement of "magnet" inside or on water surface would create "electricity" too?
Simple: you don't have pipes everywhere you need electricity.
i read and ask some more people, i guess i understand a little bit more now :approve:
since we know V stands for different potential (pressure), I = current and R = resistance.
high R = less V being deduct from actual V
high R = low I (hard to move coz blocking all the way)
so low I = less V being deduct (or just high V)
:-p
i just replay to richard wolfson physics video.
i guess the reason i said high volt = low amp is because i am dealing with "watt".
http://www.answers.com/topic/watt said:
The standard unit of measurement of electrical power. One watt is one ampere of current flowing at one volt.
so W = V * I, so to get a 5 watt power, we could set 5 volt (pressure) and 1 amp current or, 1 volt (pressure) with 5 amp current.
hmm.. still some question in my mind. nvm , i get back later.
yeah but we didnt have cable running everywhere we wanted electricity originaly. The real reason is that 1) you still get pressure drop allong a pipe with fluid flowing through it, caused by friction with the wall
http://www.engineersedge.com/fluid_flow/pressure_drop/pressure_drop.htm"
and 2) although water could be used perhaps more eficiently than electricity to gererate motion with either hydraulic cylinders or hydraulic motors, it would be more dificult to generate heat or light from water pressure and as far as i am aware a suitably small water semiconducter has not been developed so everything with semiconductors in it would not be possable if we used a water power transport system.
:rolleyes:
Sleepsleep was talking about using pipes to carry electricity, not running equipment on hydraulics.
:-p
I don't know what you mean by "deducting" V. The law is V= I R.
In other words, for a given R, I is proportional to V: the larger V is the larger I is.
For a given V, I is inversely proportional to R: the larger R is the lower I is.
is that possible for R remains unchanged?
since 100% (actual) pressure could only be achieved when R is 100% too.
pressure could only drops, when resistance is drops too.
when resistance drops, then current would increase ONLY if pressure remain the same.
(is that possible for it {pressure} to remain the same?)
assume resistance drop, the added % of current would be the droping percentage of pressure. (only if resistance remain the same) ~ but is that possible?
weird.
I thought he was talking about cooling the wires using water to reduce the heat generated.
Theoretically yes, it would provided an advantage but it would be painfully small for most home electronics. You'd have to have a next to 100% free supply of water to make it worthwhile.
High power electronics IS water cooled. However, at least 50% of the cooling is purely because without it the equipment would overheat and fail. The other 50% is probably because the equipment becomes very inefficient or distorted at elevated temperatures.
The problem with cooling normal copper wire is that it will always have some level of resistance, and you need to cool it quite a lot to lower it much. So to keep it at the same temperature you'll always have to have the correct temperature water flowing over it.
If, on the otherhand, you were using superconducting wire, it would definitely be worth cooling it down since it's resistance does a vertical nose dive down to zero once it gets to a certain temperature. Once you reach that temperature, the wire will no longer warm up the coolant. It'll still get warmed up by the less than perfect thermal insulation around the pipe, as the copper wire example would, but it's one less source of temperature variance.
If you were designing a high power radiotransmitter or a laser for use in fusion experiments, water cooled wires would be realistic.
In fact, a normal desktop computer is an example of a conductor that needs cooling. Without the fan running over your CPU, the heat generated by the resistance could toast the processor in not much more than a few seconds - most computers will automatically power down if the fan stops or they sense the core temperature rise above a set point (mine sounds an alarm at a temperature point a few degrees below the shutdown temperature).
Supercomputers often use liquid to cool the processors since there'll be thousands packed into quite a small space.
Another example would be a hairdryer or electric space heater. One way to look at it is that the element is warming the air flowing over it. Another way is that the air is cooling the element, which will burn out if turned on without the cooling fan.
In short, if you're putting huge amounts of current through a less than perfect conductor it'll probably need cooling. As it will if you're putting less through a conductor with a really high resistance.
As for current and voltage, the two are tied together by power. I can make 10W by having 1A at 10V or 10A at 1V (or any other combination that multiplies together to make 10). In real life, a lot of equipment wants a specific voltage and current to achieve a certain power rating (not anything that multiplies to the same rating) because the materials the equipment is made out of, as well as how it's laid out inside, set a preference for the balance of voltage and current that's sent through them - so they'll only let you reach so many watts of power if you supply it in the volts / amps form that's best for them.
An example is a lightbulb compared to a computer's CPU. Both a lightbulb and a CPU draw somewhat similar amounts of power. A lightbulb will work from the 240V mains and draws quite a small current to create that power. A CPU on the other hand converts the 240V down to just a few volts and supplies the core with lots and lots of amps to create a similar amount of power. The core has very little resistance, so it only needs a low voltage to move lots of electrons through it. If you plugged the core of your computer into the mains, it'd magically transform into a piece of worthless junk in the blink of an eye. Similarly, a lightbulb wouldn't light up anywhere near as brightly if run from the computer's low voltage / high current power supply - the low voltage wouldn't be enough to 'push / pull' the electrons through the higher resistance element, just because the supply can give out a high current, it doesn't mean it will if it's connected to a high resistance and can only put a low voltage across it.
I think of electricity like water. The current, in a circuit is like the drops of water in a stream... it's how MUCH water is there. But water doesn't go anywhere without a reason, it just sits in a puddle. The voltage is like the slope the stream is running down, it's how FORCEFUL the water is. Resistance is like putting a big paddle wheel in the stream. And the power is like how much work I can do with the torque from the paddle wheel, inside my mill grinding flour. If I have a huge river, if it's barely flowing it'll just trickle past the paddle wheel slowly. If I had a small stream that was coming down a nearly vertical slope, it'd push through the wheel quite quickly - but since there isn't so much of it, I'd still only be able to grind roughly the same amount of flour.
To grind more flour I need to keep the stream the same size, or bigger, and the speed it's moving the same of faster - one of those, or both, needs to get bigger.
My water example works for quite a lot of other electrical properties as well, like capacitance. It fits quite well.
If you've ever thought about gas or liquid flow through pipes, as someone else has pointed out, you loose flow rate and pressure in real world pipes because the water has to drag along the pipe walls, which slows the water down. You can replace my paddle wheel example with the pipe example depending on how you're feeling.
As has also been pointed out, the static and dynamic friction in the pipe idea doesn't quite apply to electrons so well. Although, the impulse of accelerating an object could be likend to the magnetic induction that occurs as electrons start to flow or need to change direction. That's pretty complex stuff if you're new to electronics though.
A blistering number of people don't know the difference between amps and volts or what power is. So once you get it, you're in quite a small minority.
  • · Replies 22 ·
  • · Replies 20 ·
