Thanks a lot all of you! That was quick.
So first reduced insulation between LV and center core than with HV and center core (meaning smaller and cheaper transformer). Make sense.
Then second, it's easier to place the tap changer on the outside than on the inside of the winding, ok I guess it's plausible even if I am not fully convinced, however I do see the interest in connecting the tap changer to the HV side for the reduced cable cross-section compared to the higher current LV side.
And finally, a lower leakage reactance, this one is not clear for me, I understand why it's good to have a lower leakage reactance for the losses, but I don't understand why it is getting lower when the LV is closer to the core. I mean, the leakage must be proportional somewhat to the distances between the HV and LV to the core, I don't see why having the LV side next to the core reduce the leakage more than having the HV side next to the core, is it linked to the higher currents?
Again thanks a lot for your time!
@cnh1995 @Baluncore @artis @anorlunda @berkeman
