Understanding Holomorphic Functions at Infinity: Exploring Complex Analysis
  • Thread starter quasar987
  • Tags
    Infinity
In summary, the conversation discusses the concept of a function being holomorphic at infinity and the importance of adding infinity as a point in complex analysis. It also touches on the significance of infinity as a point in the complex plane and how it allows for a more uniform approach in analyzing functions.
quasar987
32
Hi, could someone explain what it means for a function to be holomorphic on [itex]\mathbb{C}\cup \{\infty\}[/itex]? More precisely, what does it mean for it to be holomorphic at [itex]\infty[/itex]. Thx.
f(z) is holomorphic at infinity if f(1/z) is holomorphic at 0. Likewise for singularities.
Thx shmoe!
Why do we never talk about continuity and differentiability at infinity for real functions?
because infinity is not part of the real line and not in terms of analysis a useful point to add in, whereas infinity is a very useful adjunction to the complex plane: poles and zeroes are far more important to a study of complex analysis than real analysis. That's just the way it has worked out, and is a very hand wavy explanation. Sorry.
The point is, trying again, that Cu{infinity} is a very important compact riemann surface. It is useful to add this point and talk about functions which take infinity as an admissible value in complex analytic terms and not for real things.But, of course, we do talk about such things for the extended real line, but they just aren't as useful, and therefore *you* haven't learned about them.
(You do make a large implicit generalization from what you know about to what *we* know about).
Is this the so-called "one point compactification" of either the complex plane or the real line? Would you also expound upon the significance of the complex characteristics of infinity (as, say, a point in the complex plane)?
TIA,
-Ben
Perhaps I should have said 'it has proved more useful'.
It is just useful to allow infinity as a point. what is the integral round a closed curve of a meromorphic function? the sum of the residues at the simple poles. what are simple poles? places where the function takes the value infinity with multiplicity 1. By treating infinity as a genuine point then we can start talking about things more uniformly.Any holmorphic function from Cu{infinty} to C is constant which is another way of stating that theorem that any bounded holmorphic function is constant.
What does it mean for a function to be holomorphic at infinity?
Holomorphic at infinity refers to a property of a complex-valued function, where the function remains analytic and well-behaved at points infinitely far from the origin.
How is holomorphic at infinity related to the concept of analytic continuation?
If a function is holomorphic at infinity, it can be extended to a larger domain through analytic continuation. This means that the function can be represented by a power series that converges for all values of the complex variable, including those infinitely far from the origin.
Do all functions have a holomorphic extension at infinity?
No, not all functions have a holomorphic extension at infinity. For example, a function with a pole at infinity (such as 1/z) cannot be extended to infinity through analytic continuation.
What is the significance of holomorphic at infinity in complex analysis?
The concept of holomorphic at infinity is important in complex analysis because it allows for the study of functions on the entire complex plane, rather than just a bounded region. This leads to a deeper understanding of the behavior and properties of complex functions.
How can one determine if a function is holomorphic at infinity?
One way to determine if a function is holomorphic at infinity is to check if it has a well-defined Laurent series expansion at infinity. If the principal part of the Laurent series has only finitely many terms, the function is holomorphic at infinity. Another way is to check if the function has a continuous limit as the complex variable approaches infinity from all possible directions.
  • Topology and Analysis
  • Calculus
  • Calculus
