Homework help on Moments of inertia of system
The discussion focuses on calculating the moment of inertia for a system of four masses positioned at the corners of a rectangle. The masses are 2.70 kg, 1.70 kg, 3.70 kg, and 2.10 kg. To find the moment of inertia about the x-axis, y-axis, and an axis through point O perpendicular to the page, one must apply the formula I = mR², where R is the distance from the axis to each mass. The center of mass is not required for this calculation; instead, each mass should be multiplied by the square of its distance from the respective axis, and the results summed.
  • Understanding of moment of inertia calculations
  • Familiarity with the formula I = mR²
  • Knowledge of mass distribution in a rectangular coordinate system
  • Basic principles of rotational dynamics
  • Research the calculation of moment of inertia for composite bodies
  • Learn about parallel axis theorem applications
  • Explore the concept of center of mass in multi-body systems
  • Study the effects of mass distribution on rotational motion
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to enhance their understanding of moment of inertia calculations.
Dr_bug
Four masses are held in position at the corners of a rectangle by light rods.Find the moment of inertia of the system about the x axis.Find the moment of inertia of the system about the y axis.Find the moment of inertia of the system about an axis through O and perpendicular to the page. M1 (kg) M2 (kg) M3 (kg) M4 (kg) the picture is attached.
2.70 1.70 3.70 2.10
I=mR2
I wasn't really sure how to start. Should I first figure out the center of mass and then use that value to find the inertia?
The center of mass has nothing to do with this. Just multiply each mass by the square of its distance from the appropriate axis and add all the terms together.
  • · Replies 21 ·
