Homework help: Transformer Current
The discussion centers on the factors influencing the secondary current (I2) in a transformer, specifically how it relates to the load resistance (R), primary current (I1), and the turns ratio (N1:N2). Key equations include I2 = V2/R and I1 = I2 * N2/N1, which establish the relationship between primary and secondary currents. The magnetizing current (Im) is also discussed, highlighting its role in maintaining magnetic flux in the core. The conversation concludes that while I1 is influenced by R, the impedance (Z) in the primary coil is not constant and varies with the load.
  • Understanding of transformer principles and operation
  • Familiarity with electrical impedance and its effects on current
  • Knowledge of alternating current (AC) circuit analysis
  • Basic grasp of magnetic flux and its relationship to current in transformers
  • Study the concept of magnetizing current in transformers
  • Learn about the effects of load resistance on transformer performance
  • Explore the relationship between turns ratio and voltage/current transformation
  • Investigate the impact of core material permeability on transformer efficiency
Electrical engineers, physics students, and professionals involved in power systems and transformer design will benefit from this discussion, particularly those seeking to understand current relationships in transformers.
Aryan Andaleeb
If we denote:
Alternating current in the primary coil as I1
Alternating current in the secondary coil as I2
Similarly, we denote,
Number of turns in primary coil as N1
Number of turns in secondary coil as N2
And, we denote,
Voltage generated across primary coil as V1
Induced voltage across secondary coil as V2
Okay, now let the load, R, be connected to the secondary.
Now, exactly on which factors do the value of I2 depend on?
Here,
V1 / V2
= N1 / N2 = I2 / I1 -------i
Again,
I2 = V2 / R ------------------------ii
Besides,
I1
= V1 × Z --------------------iii
[Where, Z means electrical imppedance in the primary coil, generated by the ac generator]
[/B]
But,
I2
= I1 × V1 / V2 ----------------- iv
and also,
I2 = I1 × N1 / N2 -----------------v
Where, each of the magnitude on the right-hand side of both the equation is constant.
So, is the value of I2 dependent upon R ?
If the answer is yes, then,
as R is variable, so,(according to equation no.ii) I2 is variable.
Therefore, (according to equation no.iv and v) I1 is variable.
But, according to equation no. iii
I1 = V1 × Z
Now, I'm getting a bit confused. How can this equation (equation no.iii) be true?
Since,
I1 is variable depending on R
But, at the same timeV1 is constant.
Z
is constant.So, its getting difficult to predict the controlling factors of I2
Please help. I've stuck in this problem for a few days!
Welcome to the PF.
The source voltage V1(t) is transformed to the secondary voltage V2(t) by the turns ratio. The secondary current is determined by the secondary voltage and the load resistance. For the ideal transformer driven by an ideal voltage source (that has zero internal resistance), that's about all there is to it. Does that help?
That's alright.
But how is the primary current determined in a transformer?
And thanks a lot for your help.
Typically V1, R and N1:N2 are known. The sequence of working out the other variables is usually as follows...
Secondary voltage is determined by the winding ratio..
V2 = V1 * N2/N1
Secondary current is determined by the load...
I2 = V2/R
Primary current is determined by the winding ratio...
I1 = I2 * N2/N1
V2 = V1 * N2/N1
I2 = V2/R
I1 = I2 * N2/N1
Okay, I agree with you.
But, now, isn't this true as well?
I1 = V1 × Z
[Where, Z means electrical impedance in the primary coil, generated by the a.c. generator]
I1 = V1 × Z
Are you familiar with the concept of magnetizing current? Im=V1/Z will be the magnetizing current which is required to create the necessary magnetic flux in the core. When secondary is open, I2=0. Hence I1=Im. Now when you connect a load (say R), current I2 will flow in the secondary given as I2=V2/R. This will create its own mmf to demagnetize the primary mmf . Hence, to cancel out this demagnetizing mmf, primary draws a current I1 which is 180o out of phase with I2. Also, its magnitude is N2/N1 times that of the primary current such that there will mmf balance N1I1=N2I2. Note I1 and I am aren't same. The "net" primary current will be vector sum of I am and I1 (which themselves are 90° apart electrically). Im=I1 when I2=0. In introductory physics course, I am can be neglected since it is really small compared to I1. That's where permeability of the core material comes in picture. I am in case of air core would be 1000 times less than that in case of air core. This is just a brief description. You'll get more from experts here on PF.
I1 = V1 × Z
Yes but Z isn't constant. The current in the secondary causes a flux which opposes the primary flux and effectively reduces the impedance Z.
Edit: Actually I think the equation should be I1 = V1/Z
Edit: Cross posted with chn1995
cnh1995 said:
Im in case of air core would be 1000 times less than that in case of air core.
What do you mean here?
Permeability of iron is 1000 times more than that of air. So, magnetizing current required will be 1000 times less i.e. you'll get same magnetic flux with 1000 times smaller current. You'll need to study the magnetic behavior of transformer.
