Hot air balloon - Ideal gas law
The discussion revolves around estimating the required temperature of air inside a rigid hot air balloon to achieve lift-off, utilizing the ideal gas law and principles of buoyancy. The problem involves calculations related to volume, mass, and forces acting on the balloon.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore relationships between buoyant force, mass of air, and the ideal gas law. There are attempts to express the mass of hot air in terms of pressure, volume, and temperature, while questioning the utility of various variables and constants involved.
Participants are actively engaging with the problem, providing insights and corrections to each other's algebraic manipulations. Some guidance has been offered regarding the relationships between the variables, and there is ongoing exploration of the implications of using molar mass in the calculations.
There are uncertainties regarding the values of certain variables, such as pressure and molar mass, as well as assumptions about the conditions inside and outside the balloon. The discussion reflects a mix of initial confusion and gradual clarification of the problem's setup.
andyfry
Estimate the required temperature of the air inside a (rigid) balloon in order for it to achieve lift off.
Volume 2000m3
\summass, mtot=920kg
pV=NkT
p=\frac{Force}{Area}
\rho=\frac{m}{V}
We require
Fup>(mair+mtot)g (assume equal to solve)
and Fup=\rhoVg
Not entirely sure how to relate this to the ideal gas law, but have tried
Fup=\frac{NkTA}{V}
(from p=\frac{F}{A})
so T=\frac{Vg}{NkA}(mair+mtot)
But I'm left with an N which I don't know, and also an mair which I also don't know. I assume mair=N(mass of 1 molecule) but subbing this into the equation would still leave one N and a the mass of 1 molecule of air, which i do not know.
Hopefully my attempt is at least going in the right direction...
andyfry said:
pV=NkT
\rho=\frac{m}{V}
We require
and Fup=\rhoVg
This looks good up to this point. Can you find an expression to substitute for mair, the mass of hot air? It involves the ideal gas law and the molar mass of air.
well mair=nM
where M=molar mass of air
so subbing into pV=nRT
gives mair=\frac{pVM}{RT}
Is this what you mean?
Can't really see how this is helpful though. Still leaves me with unknowns of p, \rho, and M after subbing into intitial equations.
How does using the molar mass of air, M, instead of mair help? They are both unknown.
EDIT:
\rhoinV=\rhooutV+mtot
\frac{PMV}{RT_{in}}=\frac{PMV}{RT_{out}}+mtot
(assuming P in and out are equal)
Rearanging for Tin
Tin=\frac{PMV}{R}(\frac{RT_{out}}{PMV}+\frac{1}{m_{tot}})
Tin=Tout+\frac{PMV}{Rm_{tot}}
assume Tout=283k, P=101kPa, M=28.97, R=8.314
Tin=283+\frac{101000*28.97*10^{-3}*2000}{8.314*920}=1048k
Which doesn't seem to be quite plausible? Would expect a value of maybe half that...
Can someone check my method please??
andyfry said:
EDIT:
Actually, it's
ρinV + mtot = ρoutV​
The mass of the balloon (including the hot air inside it) equals the mass of the displaced air, ρoutV.
You're on the right track, be careful with the algebra.
Redbelly98 said:
Actually, it's
Ah, that might help!
rearranging (properly!) for Tin now gives an answer of 450k, which I believe is the right answer.
Thanks a lot for your help! :)
andyfry said:
450k
Yup, looks good to me :smile:
You're welcome.
10K
