I Learning GR with Leonard Susskind: Prerequisites Needed?
  • I
  • Thread starter Thread starter docnet
    Gr Lectures
docnet
TL;DR Summary
How good are Leonard Susskind's lectures on YouTube for learning GR?
I took differential geometry and introductory physics sequence in college, but not special relativity.
Are there better sources to learn from?Thank you
Edit: is learning SR a prerequisite for GR?
docnet said:
Summary:: How good are Leonard Susskind's lectures on YouTube for learning GR?
Yes. GR reduces to SR locally. That fact is used a lot. If you don’t understand SR then that will be confusing.
Likes vanhees71 and docnet
Even more than that, SR is (as the name suggests) a special case of GR so effectively you will be learning both at the same time if you start from GR. However, in many cases the discussion in a typical GR course will involve referring back to the special case of SR. Starting with GR will therefore often require you to accept some things at face value as reasonable.
I'd recommend checking out the GR lecture series from MIT OCW rather than that one. Susskind aimed his at a general audience. The ones from MIT are an actual course.
Likes vanhees71, PeroK and docnet
I just learned from an advertizement by Springer that R. J. Adler wrote a brandnew textbook on GR for advanced undergraduates. As his older graduate-level book (1965, 1975) it looks like a gem but is much more introductory
https://doi.org/10.1007/978-3-030-61574-1
I think for a first encounter with GR you need a good understanding of SR. My favorite at the introductory level for both is Landau and Lifshitz vol. 2.
Likes Orodruin, Dale and docnet
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
