How Can I Achieve 270 Degrees Celsius with a 12V 500mA Adapter and Wire?
  • Thread starter Thread starter jemmap
    Building Element
To achieve 270 degrees Celsius with a 12V 500mA adapter, it's crucial to match the resistance of the nichrome wire to the adapter's output resistance for optimal power transfer. Users suggest measuring the adapter's output resistance by testing it with different load resistances. The configuration of the wire, such as using a single long piece or multiple short lengths in parallel, impacts heat generation. Copper wire is not recommended; nichrome wire is preferred for its heating properties. Properly configuring the wire and ensuring the right resistance will help achieve the desired temperature.
jemmap
im trying to produce about 270degrees celcius and have a 12v 500ma adapter i plug into the wall, I've wound the wire from a toaster round a nail, imn not getting enough heat though. I've tryed 5 small lenghts in parallel a single long piece, a single short piece...
so tell me, what configuration will give me the most heat?
would it be better to use copper wire? if so can anyone recommend a thickness? tryed it with thin wire but only the adapter heated up. i don't really want to get into calculating the resistivity of each metal etc, just want someone to help me get 270 degrees with a piece of wire and a 12v 500mA adapter.
ive seen it done before, just didnt take note of the thickness/turns
thanks
Given the wall adapter as a starting point, you will get the most power out of it if the resistance of the nichrome toaster wire matches the output resistance of the wall adapter. You measure the output resistance of the wall adapter by loading it with two different load resistances, and calculating the open circuit voltage and output resistance based on those two points. Do you know how to do that?
yeah, I've pluged it into an old psu, working great now :D
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
