MATLAB How Can I Automate Input for an MRWE Application in MATLAB?
  • Thread starter Thread starter natejensen
    Matlab Running
The discussion revolves around running an executable from MATLAB that requires user input for a file, which complicates automation. The user successfully executes the program using the system command but cannot pass input commands directly, as the executable prompts for input in a separate window. Attempts to use the Java Robot Class for automation are hindered because the executable runs in blocking mode, preventing further execution of MATLAB code until the executable is closed. A suggested solution is to run the executable in the background using the ampersand (&) symbol, allowing MATLAB to continue executing subsequent lines of code. Additionally, to ensure the executable window is in focus for the Robot Class to work, minimizing the MATLAB window is recommended. A user also inquires about automating the input of multiple files in a loop, seeking guidance on dynamically changing the input file name within the loop.
natejensen
I have already referred to this posting:
http://www.mathworks.com/matlabcentral/newsreader/view_thread/241352
so I know the basics of running an executable from Matlab and inputing a file for it to run.
My problem is that because of the way my executable was written, I can only run the executable and not pass commands to it from Matlab. I have tried passing commands to the executable from the command window and that does not work either.
This works fine:
system('C:\...\executable.exe')
And the only thing any of these:
system(['C:\...\executable.exe<' input_file])
system(['C:\...\executable.exe ' input_file])
system(['C:\...\executable.exe <' input_file])
do is just run the executable.
When the executable is run, a "dos like" window pops up with a prompt to input the input file. From there I can manually enter in the input file, but that isn't really all that helpful if I want to run it 1000 times.
This "dos like" window is an MRWE Application Framework. I tried searching "matlab mrwe," but just came up with a bunch of dead links. It doesn't seem like absoft is supported by Matlab, but I just need to input a few lines of text. It shouldn't be too hard right?
Alright so I've been messing with that Java Robot Class stuff, and found this:
http://undocumentedmatlab.com/blog/gui-automation-robot/
I tried following their example but it's not working yet. This is what my code looks like now:
robot = java.awt.Robot;
robot.keyPress (java.awt.event.KeyEvent.VK_V);
robot.keyRelease (java.awt.event.KeyEvent.VK_V);
robot.keyPress (java.awt.event.KeyEvent.VK_E);
robot.keyRelease (java.awt.event.KeyEvent.VK_E);
robot.keyPress (java.awt.event.KeyEvent.VK_R);
robot.keyRelease (java.awt.event.KeyEvent.VK_R);
robot.keyPress (java.awt.event.KeyEvent.VK_ENTER);
robot.keyRelease (java.awt.event.KeyEvent.VK_ENTER);
When I run this, the code gets stuck on the first line. After the system command, the executable asks for an input file. It doesn't matter if I click on any other window (Matlab, the executable, my computer, whatever...) the code will not go to the second line until I either manually type in an input file, or close the executable.
I also tried switching the first two lines, but to no avail.
Any ideas?
I know that I'm the only replying in this thread, so I don't know if anybody cares, but here is the answer.
This is because you run your executable in blocking mode. Instead, run your executable in the background:
system('C:\...\executable.exe &')
Note that the robot key-press require the target application to be in focus. You can do this by minimizing the Matlab desktop window:
com.mathworks.mde.desk.MLDesktop.getInstance.getMainFrame.setMinimized(true);
Yair Altman
http://UndocumentedMatlab.com
Great work. I have ten data input files named (data1,data2,...,data10), Is it possible to make loop that consider the new name of input file??. In other way suppose we have something like :
for i =1:10
system('abcd.exe &');
robot.keyPress (java.awt.event.KeyEvent.VK_D);
robot.keyRelease (java.awt.event.KeyEvent.VK_D);
robot.keyPress (java.awt.event.KeyEvent.VK_A);
robot.keyRelease (java.awt.event.KeyEvent.VK_A);
robot.keyPress (java.awt.event.KeyEvent.VK_T);
robot.keyRelease (java.awt.event.KeyEvent.VK_T);
robot.keyPress (java.awt.event.KeyEvent.VK_i); -------------> change i to be 1,2,3,...10
robot.keyRelease (java.awt.event.KeyEvent.VK_i);-------------> change i to be 1,2,3,...10
end
how to pass the file name as a variable?
