How can I create a accurately-measured conductive strip for electronic projects?
  • Thread starter Thread starter geolej
The discussion revolves around methods for creating an accurately-measured conductive strip for electronic projects, focusing on materials and techniques for achieving consistent resistance measurements. Participants explore various approaches, including conductive paints, copper strips, and alternative materials.
  • Experimental/applied
  • One participant reports difficulties in achieving consistent resistance measurements using a paint/graphite mix, noting erratic values.
  • Another suggests using stick-on copper strips or printed circuit boards to create a more reliable conductive track.
  • A participant mentions the potential use of conductive paint, expressing skepticism about its effectiveness due to the non-conductive nature of the paint surrounding conductive particles.
  • One contributor shares a link to a resource related to conductive materials, possibly for further exploration.
  • Another participant proposes carbon tape and Teledeltos paper as alternatives, questioning the availability of the latter.
  • Conductive antistatic foam is mentioned as a possible material with measurable resistance.
  • A suggestion is made to use thin copper with a four-wire measurement technique to improve accuracy in resistance measurement.
  • Aluminum cooking foil is proposed as a simple and effective material for creating a conductive strip.
  • A participant recommends using a conductive paint marker made with silver ink and mentions conductive glue as additional options for creating conductive surfaces.
  • One contributor shares their experience with using graphite on a plastic film to achieve uniform resistance, emphasizing the importance of even application.
Participants express a variety of opinions on the best materials and methods for creating a conductive strip, with no consensus reached on a single solution. Multiple competing views and approaches remain present in the discussion.
Some participants express uncertainty about the effectiveness of certain materials, such as conductive paint and graphite, and highlight the importance of application techniques for achieving desired results. The discussion includes references to specific products and methods that may have varying levels of success.
geolej
I am attempting to create a line (5" long by .5") that I can then measure the resistance between. I have tried creating a paint/ graphite mix but no matter what consistency I make by diluting it with acetone, I can't get a accurate distribution of values. They jump erratically when I measure them.
You can get stick-on copper strip. Would this be OK?
Or, you could just have a track like that on a printed circuit board.
If the problem is making contact to the painted strip, maybe you could try painting it between two copper tracks on a printed circuit board and making contact to those for testing.
I have some supposedly conductive paint but it has never been any good. The particles in it are probably conductive but each one gets non-conductive paint around it so the net result is non conductive.
What are you trying to do?
http://grab.by/Sqy
For a glass replacement I have notecards or some bendable object that makes contact with two conductive surfaces, that I can measure the resistance between. Cooper doesn't have enough measurable resistance as far as I know. The end project is a "touchscreen".
What about carbon tape?
Good idea.
I also thought of Teledeltos paper. I don't even know if you can still get it. It was like carbon paper but intended for plotting electric fields.
Also, there is the conductive antistatic foam that you get when you buy integrated circuits. This is conductive but with measurable resistances.
Use thin copper and four wire measurement.
Put 1 amp DC through the copper. (If copper is thick use 10 amp)
Have voltmeter with probes 1 inch apart.
Measure the voltage drop across 1 inch of copper using the probes.
Aluminium cooking foil glued to a suitable flat surface and the aluminium then cut to size.
You might be able to use a conductive paint marker http://www.pemro.com/items.asp?Cc=CONDPEN&iTpStatus=0&Tp=&Bc= they are made with silver in the ink and so are conductive. Also, The Electronic Goldmine has conductive glue http://www.goldmine-elec-products.com/prodinfo.asp?number=G16133 which you might be able to use. I made an electrostatic speaker, and to make the diaphram, I used a piece of projector plastic covered with graphite which was rubbed into the plastic, the trick to getting uniform resistance was to apply the graphite evenly over the film and rub in using another transparency.
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 42 ·
