How can I determine the IR frequency?
  • Thread starter Thread starter shlomo127
    Frequency Ir
To determine the IR frequency of two IR Text Messengers, a spectrograph can measure the wavelength, which typically ranges around 890-950nm for common IR diodes. The data transmission frequency is usually between 100-1000 bits per second, which can be tested using a photodiode and an oscilloscope. The light frequency may not be crucial, as the devices are likely tuned to specific pulse frequencies for communication. Attempting to intercept transmissions would require knowledge of cryptography, as the data packets are encrypted. Understanding these aspects is essential for effectively analyzing the devices.
shlomo127
Hey, I found this forum on good, so I apoligize for my lack of knowledge, but I am trying to determine the IR frequency of these two IR Text Messengers.
Theyre designed to only send messages to one another, so is there any way I could test to discover their frequency? Would it be written anywhere on the inside of the device, and if so where and how.
Thanks so much, and I apoligize if i posted this in the wrong place.
Zachary
To measure the wavelength/frequency of the light you would need a spectrograph.
In practice the easier way is to look for the cheapest IR diodes in a parts catalogue, that's what they will be using. Generally around 905nm but the wavelength control of these parts is poor so the output will be somewhere around 890-950nm
Sorry to ask a stupid question, but what's that in Hurtz?
About 10^16 hz, you don't normally use frequency for visible wavelengths.
Do you mean the data frequency that the code is sent at rather than the frequcy of the light?
Thats usually around 100-1000 bits/second, you could get a photodiode and hook it upto an oscillopscope.
Oh, ok.
Truthfully I am not 100% sure which I want, but ill forward it to my Professor.
Thanks so much!
Zachary
You should also be aware that, if the two devices are designed to only send messages to each other, then the frequency of light being used may not be the key you're looking for. In class, we built IR com-units that sent data in pulses. The frequenc of the light was irrelevant; the receiver was tuned to look for a specific frequency of pulse.
Ya. if you're thinking you can 'intercept' transmission or something that's not what you're looking for at all (however, you may be able to jam transmission but just spamming IR in the approximate frequency). To 'intercept' you're talking about cryptography. (Since packets between the two things are encrypted)
  • · Replies 42 ·
  • · Replies 43 ·
