How can I integrate dx/dt = u(x) in my differential equations class?
  • Thread starter Thread starter steveangel
    Integrating
The discussion centers on solving the differential equation dx/dt = u(x) in a differential equations class. The user, Steve, is confused about integrating the left side of the equation, specifically ∫dx/u, where u is a function of x. Participants clarify that the integral represents the integral of 1/u with respect to x and emphasize the importance of initial conditions, u(x,y=0) = 2 for x < 0 and 1 for x > 0, in solving the problem. They conclude that the initial data is crucial for determining the behavior of u and for integrating the equation correctly.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with integration techniques, particularly with respect to functions
  • Knowledge of initial value problems in the context of PDEs
  • Basic concepts of characteristics in partial differential equations (PDEs)
  • Study the method of characteristics for solving PDEs
  • Learn about initial value problems and their significance in differential equations
  • Explore integration techniques for functions of multiple variables
  • Investigate the relationship between partial derivatives and their implications in PDEs
Students in differential equations courses, educators teaching ODEs and PDEs, and anyone seeking to deepen their understanding of integrating functions in the context of differential equations.
steveangel
In my differential equations class I have been given a problem which involves solving dx/dt=u where u=u(x)
I know that this is done by separation such that ∫dx/u = ∫dt, and then the constant of integration found using initial conditions, however I am getting myself all worked up and confused as I don't know how to treat the integral on the left, i.e. ∫dx/u
Any help would be greatly appreciated
Thanks in advance,
Steve
What is the question? To solve for x(t)? The integral on the left is simply the integral (with respect to x) of 1/u And since you have u as a function of x, then you're integrating a function of x with respect to x. And on the right-hand side, you're integrating 1 with respect to t.
Thanks for the quick reply :)
The actual question is to use the method of characteristics to solve a PDE
From this I have obtained that one of the characteristic equations is dx/dt = u, which I need to rearange to get an equation for x in terms of t.
I have also been given the intial data : u(x,y=0) = 2, x<0 and 1, x>0 however I believe this is not needed until later in the question
Am I being really stupid?!?
All I know is that u=u(x), and so I don't know how to integrate 1/u wrt x. Surely its not ln(u) because u doesn't equal x?!?
Ive been stuck on this all day and its starting to drive me mad so I am sorry if the answers staring me in the face
Its not ln(u). In fact, dx/dt = u is not enough information to get an equation for x in terms of t. I reckon you will have to use your initial data somehow.
In your initial data, you have the x dependence of u at y=0. So this implies you could write u as a function of y and x. So this means you have:
dx/dt = u(x,y)
But you don't know how u depends on y (or how y depends on x or t), so I think you still don't have enough information.
Ok, so I am clearly missing something blindingly obvious:
Initial data: t=0, u(x,y=0) = 2, x < 0 and 1, x > 0
I have 3 characteristic equations given by:
1. du/dt=0 therefore u is constant wrt t
2. dy/dt=1 therefore y=t + constant
Using that at t=0, y=0 we get that constant = 0 and so y=t
3. dx/dt=u therefore ∫dx/u = ∫dt
As far as I can see there is no way to reconcile the problem using the other two equations.
It follows that the initial data must therefore be the key.
Would putting in the value of u for x (being positive or negative) invalidate the DE
i.e. for x positive: ∫dx/1=∫dt therefore x(+) = t + constant
and for x negative: ∫dx/2=∫dt therefore x(-) = 2t + constantYour opinion on this would be greatly appreciated
Steve
Well, you've now told me there are more equations! OK, so y = t +constant. So this means that when t=0, y=constant. This doesn't mean the constant is zero.
The problem does look pretty tricky actually. It might help to consider product rule, etc. I'm not sure. I'll come back to this tomorrow!
Sorry, I didnt think the other equations would make a difference to the one in question, which is probably the reason why I've been sweating over this all day.
I'm pretty sure that the constant does equal zero since the initial data gives at t=0, u(x,y=0)
Thanks again for your help
Oh I see, yes you are right, y = t. Well from there, I think it is simpler to replace y by t in all the places where y appears, so then you just have 3 variables: u, x and t.
So now you have 2 important equations: du/dt=0 and dx/dt=u. You could try writing out the full differential for u, and use these equations to get a relationship between the two partial differentiations. But I don't think this gives u(x)...
  • · Replies 44 ·
