Auto/Motor How Can I Make My DIY Swirl Push Maker Create Perfect Spirals?
The forum discussion centers on creating a DIY Swirl Push Maker for producing spiraled food using a pressing machine. Users suggest utilizing a turning table or Lazy Susan design to facilitate the circular motion necessary for achieving the desired spiral shape. The pressing mechanism employs a 12V actuator for dough extrusion, while a stepper motor can control the rotation and lateral movement of the table. Key considerations include the speed of the rotating table and the method for off-loading the spirals, potentially using a conveyor belt or screen carrier for deep frying.
  • Understanding of mechanical design principles, particularly in food machinery.
  • Familiarity with stepper motors and their application in motion control.
  • Knowledge of extrusion techniques for food processing.
  • Basic skills in woodworking or material assembly for constructing the apparatus.
  • Research the design and implementation of Lazy Susan turntables for food applications.
  • Explore stepper motor control techniques for precise movement in DIY projects.
  • Investigate extrusion nozzles and their impact on dough shaping and flow rate.
  • Learn about conveyor belt systems suitable for food handling and processing.
Food engineers, DIY enthusiasts, and hobbyists interested in food machinery design and automation, particularly those focused on creating unique food shapes and textures.
  • #31
I'm seeing this get more and more complicated. I agree that either the feed rate or the RPM of the disc would need to change as the spiral grows (remember our old records - the speed of the stylus through the final was much greater at the outside edge of the record than those inner groves). This is basic trigonometry.
At this point, I think it would be far simpler, and far more flexible to build/buy an x-y table. That could be programmed to adjust the speed to match the (presumed) constant feed rate, and could be easily reprogrammed for different shapes and sizes. And if you change dough recipes, or anything else in the feeder, you could adjust the programming of the x-y table to match. You won't be constricted by purpose-built hardware. The dough might even change batch-batch or with temperature, you could have a program ask for a feed rate.
This looks pretty cool, I really think that once you get it working, you will want to make different shapes/sizes. Keep us up to date on your progress! I'm getting tempted to make one myself now.
Likes junasiv
  • #32
I'm also curious about the "12V actuator" for the dough. Is this a solenoid providing pressure, or a positive displacement type device? I really think you want something that provides a positive displacement, so you drive a set volume of dough per unit time. A motor/stepper-motor and threaded rod or lead screw would do it.
  • #33
That would be ideal but, I don’t think the OP has the where-with-all to pull that off. Right now he is somewhat MIA.
  • #34
The OP has not provided any details on this, other than his image above.
  • #35
AZFIREBALL said:
junasiv: What country are you in? You might be able to visit a pastry shop and see the filler in action. I used one for years...they work great!
Hi AZFIREBALL,
I will check some store. I am from Sri Lanka.
  • #36
AZFIREBALL said:
Is the batter stiff enough not to flow by gravity? If it is very stiff, the supply container can be placed overhead. If it flows, due to gravity, it will need to be at table level or below and allow the pressure to move it through the tube, and out the nozzle. I would think it needs to be stiff so it does not flatten out too much on the table after being extruded and prior to being fried.
The batter is still enough to flow by gravity, but it won't fall like a straight line since it has some the star design around it. I guess it can go around the tube without breaking into pieces. I will try adding a straw to test it out.
  • #37
Hi NTL2009,
Thanks for your ideas!
Sure I will keep you guys up to date on my progress. I am checking on the x-y table too, also thinking of adding arduino to sync the speed. Looks like acutator internally has the threaded screw. I will find out more on this.
  • #38
AZFIREBALL said:
junasiv: Can you tell us how automated you would like the operation to be. Will someone be operating and monitoring this system at all times while in use? How many hours per day do you expect the system will be in operation? Do you have any special operational or regulatory requirements. How about cleaning requirements? Any material restrictions or code requirements?
Hi Azfireball,
Yes!. Because someone should be watching the shape and make sure it is spiral and the edges around it is sharp (star). Also If we separate the frying portion out of this, I can have this machine producing the dough spirals continuously and have many oil frying cookers. Another reason is, the dough gets harder if we keep out for sometimes, even the spirals. The dough is kind of made instantly during this process.
It is kind of a low to medium level operation. So I guess the machine will operate 3-4 hours.
Not as such, but it is should adhere to the Food manufacturing standards, mostly Clean environment.
The Dough cylinder is detachable. So it is a manual process to clean end of the day.
I am trying to avoid plastics touching the food. The food packing will have the paper insulated containers.
  • #39
junasiv said:
Hi NTL2009,
junasiv:
If you can meet the expense of a X-Y table, that is the way to go; as it will illuminate the need for a lot of mechanical design/build effort.
  • #40
AZFIREBALL said:
junasiv:
Correction:
If you can meet the expense of a X-Y table, that is the way to go; as it will reduce the need for a lot of mechanical design/build effort.
  • #41
Hi AZFIREBALL,
I am checking some manual x-y tables and add the motors to make it auto.
Do you think of any other ideas without moving parts. I was thinking some kind of path/rail/slider from the nozzle which can make that spiral. Is this possible?
Thanks
  • #42
Yes. If you are skilled enough you could make the spirals by hand. Think about how you would decorate a cake with a spiral. Do you know how you might do that?
  • · Replies 21 ·
