How can I prove the law of cosines for vectors in R^2 using lengths and angles?
  • Thread starter Thread starter smerhej
    Law
The law of cosines for vectors in R² states that for vectors v and w, the equation |v - w|² = |v|² + |w|² - 2|v||w|cosθ holds true, where θ is the angle between the vectors. The proof involves using the dot product definition, specifically |v - w|² = (v - w) · (v - w), leading to the conclusion that 2|v||w|cosθ = |v|² + |w|² - |v - w|². This establishes the relationship between the lengths of the vectors and the cosine of the angle between them, confirming that the dot product equals |v||w|cosθ.
  • Understanding of vector notation and operations in R²
  • Familiarity with the dot product and its properties
  • Knowledge of trigonometric functions, particularly cosine
  • Basic algebraic manipulation skills
  • Study the properties of the dot product in vector spaces
  • Learn how to derive the law of cosines from geometric principles
  • Explore orthogonal projections and their relationship with vector operations
  • Investigate the implications of the law of cosines in higher dimensions
Students studying linear algebra, mathematicians interested in vector calculus, and educators teaching geometric principles related to vectors.
smerhej
Prove the law of cosines: If v and w are vectors in R^2, then
|v-w|^2 = |v|^2 + |w|^2 - 2|v||w|cosθ
where θ is the angle between v and w.
2. Homework Equations /info
|x| refers to length, and not absolute value (If that doesn't make any sense then I must be wrong, but our prof. insisted on only using single lines to define a value as 'length', which can be confusing at times).
I got blindsided by this question (missed the lecture..). Even just a starting point, or even an online resource would be greatly appreciated, and to go as far fully providing me with the solution would be extremely helpful (but I suppose possibly detrimental).
Also, the rest of the assignment deals with orthogonal projections, and cross products, as well as distances from points to planes, and lines - do these sort of questions involve the usage of the above law?
Do you mean you want to prove the following:
Assuming you know the explicit form of the dot product ([itex]\vec a \cdot \vec b = |\vec a| |\vec b| \cos\theta[/itex] with [itex]\theta[/itex] the angle between them) you can just write it out using the properties of the dot product:
[tex]|v - w|^2 = (v - w) \cdot (v - w) = \cdots[/tex]
Thanks for the reply!
Alright,
So I get:
v2 - 2vw +w2 = v2 + w2 - 2vwcosθ
Then:
-2vw = -2vwcosθ
so for that to be true cosθ needs to equal 1, meaning theta is 0.
..now what?
Sorry, what?
Where is the left hand side coming from?
And what does "2vwcosθ" mean? v and w are vectors, vw is not a valid product.
Please try to be a bit more precise in your notation, it is important here!
Right sorry,
So doing the dot product of the LHS gives us:
|v|2 + |w|2
Then, we substract the lengths |v|2 + |w|2 of the RHS from the lengths |v|2 + |w|2 of the LHS , which leaves
0 = 2 |v| |w| cosθ
I'm still confused as to where this is going. I really am sorry for being so clueless on this matter.
Hold on.. If 0 = 2 |v| |w| cos (theta) then that means cos of theta has to equal 0 (so cos of 2 over pi) meaning the angle is 90 degrees, meaning the two vectors are perpendicular.
Right?
Yes, I think you are missing my point.
The equality I wrote,
[tex]|v - w|^2 = (v - w) \cdot (v - w),[/tex]
is the definition of |v - w|, because the length of a vector is the square of the dot product with itself.
You can then work out the dot product, but note that wherever you get v . v, you don't really get v2, but you get |v|2 (again, by the same definition).
Right?
Yep, and two arbitrary vectors aren't perpendicular, in general.
So there's a big clue something went wrong :-)
Alright, so let me try again.
|v-w|2 = |v|2 + |w|2 - 2|v||w|cosθ
so,
2|v||w|cosθ = |v|2 + |w|2 - |v-w|2
" " = |v|2 + |w|2 - (|v|2 + |w|2 -2(v)(w))
" " = 2(v)(w)
|v||w|cosθ = (v)(w)
Yes? But is that saying that the dot product between v and w is equal to length of v times length of w times the cosinus of the angle between them? Does that make sense?..
S=A + B
S2=(A+B)2
S.S=(A+B).(A+B)
... etc
so,
" " = 2(v)(w)
|v||w|cosθ = (v)(w)
Yes. That is how it is sometimes defined.
RGV
smerhej said:
alright, so let me try again.
q.e.d.
I can't tell if you just insulted me or told me that I finally arrived at the appropriate answer.. Either way thanks for all your help (everyone)!
Nope, it was not meant as an insult.
I was just reminding you that what you've written there is what you told us in your first post is the thing you want to prove.
The conclusion is usually taken as the definition of the inner product, as Ray pointed out. So in a sense, you'd have to read your post backwards.
Am I correct in sensing that you are a bit confused about what the definitions are here, and what you want to prove, and how to write that down?
Yes, very much so. :\
  • · Replies 24 ·
