How can I simplify finding positive odd solutions to the equation 17x+11y=1000?
  • Thread starter Thread starter MSG100
    Variables
The discussion focuses on finding positive odd integer solutions for the equation 17x + 11y = 1000. Initial attempts involved using a Diophantine approach, yielding general solutions but not positive integers. A second method tested odd values of x within a specific range, resulting in three valid positive odd pairs: (9, 77), (31, 43), and (53, 9). To simplify the process, it was suggested to leverage the Diophantine solution by determining specific values of k that ensure both x and y remain positive and odd. Ultimately, the values of k identified were 177, 179, and 181 for achieving positive odd solutions.
MSG100
Problem:
Find all the positive integer solutions where x and y are odd numbers, to the equation: 17x+11y=1000
Attempt of solution:
First attempt:
With Diophantine equation have gotten the answers:
x=2000
y=-3000
and the general solutions will be:
x=2000-11k
y=-3000+17k
Now I don't know what to do.
Second attempt:
If I skip the Diophantine solution and do it like this:
y=(1000-11x)/17
Now I see that x has to be in the interval 0≤x≤58 if y should be positive.
If I test all the odd numbers in the interval I'll get 3 solutions when both x and y are positive and odd numbers. The solutions are:
(x, y) = (9, 77), (31, 43) and (53, 9)
This solutions (which should be the right answer) takes a lot of time because you have to test all odd numbers between 0 to 58 (29 different numbers).
I need help to find an easier solution.
MSG100 said:
Problem:
First attempt:
x=2000
y=-3000
x=2000-11k
y=-3000+17k
Second attempt:
y=(1000-11x)/17
If you don't want to check all those numbers you should use your Diophantine solution. You just have to figure out what values of k will make both x and y positive. There aren't that many.
Likes 1 person
Thanks, that makes sense!
Then I just have following numbers k= 177, 178, 179, 180, 181 to make x and y positive and only k= 177, 179, 181 to make them positive AND odd.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
