How can I speed up the electrolytic rust removal process?
  • Context: High School
  • Thread starter Thread starter the mitch
    Rust
The discussion revolves around methods to expedite the electrolytic rust removal process, focusing on the chemistry involved, power sources, and the effects of various parameters on the efficiency of the process. Participants explore theoretical and practical aspects of the technique.
  • Experimental/applied
  • One participant inquires about ways to speed up the rust removal process by lowering resistance in the solution, which currently contains sodium bicarbonate.
  • Another suggests increasing the voltage as a potential method to enhance the process, while cautioning about the production of hydrogen gas.
  • A participant mentions the need for a high-capacity power source, specifically an arc welder with 100 amps and 50 volts DC.
  • One suggestion is to increase the concentration of the sodium bicarbonate solution to improve efficiency.
  • Another participant describes the basic mechanism of electrolytic rust removal, comparing it to the electrolysis of water and noting that it converts rust to iron.
  • A participant shares personal experience using an auto battery for rust removal, emphasizing the importance of understanding the load characteristics of the solution and its non-linear response to voltage changes.
  • There is a discussion about the potential benefits of using a larger electrode and the possibility that a weak acid might be more effective than sodium bicarbonate.
  • Concerns are raised about the heating of the solution due to current flow, with a warning to maintain the solution level to prevent boiling.
  • One participant notes the importance of matching the electrode material to that of the rusty parts to avoid unintended plating effects.
Participants express various methods and considerations for improving the electrolytic rust removal process, but there is no consensus on the best approach or the effectiveness of the proposed solutions. Multiple competing views and uncertainties remain regarding the optimal parameters.
Participants acknowledge limitations in their knowledge about the chemistry and physics involved, particularly regarding the behavior of the solution under different conditions and the implications of using different electrode materials.
the mitch
is there any way to speed up the rust removal process.right now ther is a basic base in the water aka sodium bicarbonate. i need some way of speeding up the current flowing through by lowering the resistance.
Maybe the chemistry guys can help. Do you have a means to increase the voltage? Be careful of the hydrogen gas.
its outside, i need to find an arc welder for power sorce. 100 amps, 50 volts dc, 100% duty cycle
have you tried increasing the concentration of the sodium bicarbonate solution.?
How does electrolytic dust removal work?
same electrolsis of water to make hydrogen. just it converts the base rust to iron and the rest flakes off. just google electolytic rust removal. amazing what it can do.
Yeah it does work great, I used it to remove rust on some very old tools from my dad. I was in no hurry so I just used an auto battery.
It is a process I have little knowledge about but the basic are, I think:
Consider the solution as the “load” on the power supply (welder).
The load is the circuit component that restricts current flow.
The solution I believe will not provide a linear response to voltage changes, if one doubles the voltage I do not believe the current will double as it would using a resistive load.
I think using a larger electrode will increase the current flow.
As mentioned a higher concentration of bicarb should help, perhaps a weak acid may do better, but I’m out of my basic knowledge on that.
The load determines the amount of current for any given voltage, not the welder’s output current capacity; you will be well short of that.
Lastly, if you are able to get I amp to flow at 100vc, you will be dissipating 100watts through heating the solution. It will rapidly evaporate or boil, so be careful to keep it topped up.
[edit] It is a DC welder I hope.
[edit 2] Electrode choice. I think you need to use the same material for the electrode as the rusty parts are made from, presumably iron. If you use copper, you might end up copper plating the parts (?).
  • · Replies 22 ·
  • · Replies 23 ·
17K
35K
