How Can I Use an Analog Switch to Obtain Specific Waveforms in My Circuit?
  • Thread starter Thread starter syee10
    Analog Switch
The discussion revolves around using the DG201 analog switch to obtain specific waveforms in a circuit involving TTL square waves and a sample and hold circuit. The user is facing challenges due to the lack of a simulator model for the DG201 in Labcenter Proteus and is seeking alternatives. A suggestion is made to use the CD4016 Quad Bilateral Switch, which requires a control signal (Vc) for operation. The user expresses confusion about the timing diagrams and propagation delay time control necessary for their application. Clarification on these technical aspects is needed to effectively implement the CD4016 in the circuit.
syee10
Hi all,
I have a problem with an analog switch DG201 in my analog design circuit. The circuit has 2 input at the early stage, v(t) and i(t). v(t) will be changed into TTL square wave and go through a sample and hold circuit. And the i(t) will be go through the sample and hold circuit as well. The waveform is shown in Figure where waveform A is the v(t) TTL square wave coming out from the opamp. Waveform B is the output of the sample and hold circuit for v(t).
Now my problem is how am i going to obtain the waveform C and D by using the analog switch DG201? I am using labcenter proteus and there is no simulator model of DG201 in my simulation software. Is there any other switch/device can help me to obtain waveform C and D? Help me please. Thanks..
Does your simulator have the CD4016 Quad Bilateral Switch?
http://www.fairchildsemi.com/ds/CD/CD4016BC.pdf"
Yes i have it.. can you briefly explain to me how am i going to connect this Quad Bilateral Switch?
You need a control signal (Vc) to make the connection between input and output. You'll need to look at the timing diagrams in the data sheet to see if it will be fast enough for your application.
Hi..i have read through the datasheet of CD4016.. but i still dun understand it well @@
Based on my understanding, i need to perform a propagation delay time control to signal output which is in the Figure 1,2 or 3. Am i right?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
