Chemistry How can ideal gases be used to determine the change in enthalpy using Hess' law?
  • Thread starter Thread starter Tasha Clifford
    Change Reaction
The discussion centers on the relationship between ideal gases, pressure, and enthalpy changes as described by Hess' law. It is clarified that the enthalpy of ideal gases primarily depends on temperature, not pressure, and that there can be changes in enthalpy during isothermal reactions. Participants express confusion about how to apply Hess' law to determine enthalpy changes at different temperatures. The conversation highlights a lack of understanding regarding the nature of ideal gases and their behavior in thermodynamic reactions. Overall, it emphasizes the need for a clearer grasp of thermodynamic principles to accurately address the questions posed.
Tasha Clifford
What can be done to increase the enthalpy of the following system and how this happen?
A.By increasing the pressure of the
system
B.By decreasing the pressure of the system
C.By increasing the temperature
D.By decreasing the temperature
E .no n e o f t h e ab o v e
N2O4(g)+Heat⇌2NO2(g)
∆Hrxn = +ve at constant temperature
I feel that the answer is B)
because Increasing the pressure increases the intermolecular forces Of the gas molecules but I do not see how this In effect will lead to an increase in the enthalpy
You’re on the wrong track. If they are ideal gases, do their enthalpies depend on pressure? Are you familiar with Hess’ law?
Yes Hess’s law states that the heat change in a chemical reaction is the same regardless of the number of stages taken to obtain the final product
But how does it relate to this qeustion
You didn't answer my question about the effect of pressure on enthalpy of an ideal gas.
With regard to Hess' law, suppose you knew the change in enthalpy for a reaction at one temperature and you wanted the change in enthalpy at a higher temperature or lower temperature. How would you use Hess' law to find it?
To be honest with you sir I haven’t an idea
I was just doing some research now and I found out that the enthalpy of ideal gases strictly depends on temperature and that there will be no change in enthalpy for an isothermal reaction involving ideal gases
Does this mean the answer is none of the above
I would also love to know How i could use Hess' law to find the new enthalpy as you say
Another question i have is how do i know that the Gases involved are ideal gases
or is that all gases involved in Thermodynamic reactions are generally considered ideal
I was just doing some research now and I found out that ...there will be no change in enthalpy for an isothermal reaction involving ideal gases.
This is incorrect. There is definitely a change in enthalpy for an isothermal reaction involving ideal gases. You seems to be "in over your head" with this. Are you studying thermo on you own?
No. Also, it seems like something is omitted from the problem statement. What is the exact wording of the question
Do you have a textbook?
The gases involved are not necessarily ideal, but the pressure effect is a little advanced for your apparent level of progress. Anyway, if you can't answer this for ideal gases, you certainly won't be able to for real gases.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
