How can integration by parts be used twice to solve ∫ e^at. sinωt dt?
The discussion revolves around the integral ∫ e^at sin(ωt) dt, which is part of a problem related to electrical circuits. Participants are exploring the application of integration by parts, specifically using it twice to arrive at a solution that matches a provided answer.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants describe their attempts to apply integration by parts twice, with some expressing confusion over the steps and results. Questions arise regarding the correctness of their integrations and the handling of factors such as ω.
There is an ongoing exploration of different methods to solve the integral, with some participants providing detailed steps of their approaches. Others are questioning specific aspects of the integration process, such as the inclusion of factors and the setup of the integration by parts. Guidance has been offered in the form of corrections and alternative methods, but no consensus has been reached on a single solution.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is also a noted discrepancy between the results obtained by participants and the expected answer from the professor.
alex282
∫ e^at. sinωt dt
This is the second part of an electrical circuit DE problem from our notes (first part not required to solve the above integral) however in-between this integral and the answer our professor only told us that we would get to the answer by using integration by parts twice. I am curious to understand this missed step and have tried integration by parts twice but can't seem to get the same answer as our professor gave us which should work out as:
e^at (asinωt - ωcosωt) / (ω^2 + a^2)
I would really appreciate it if someone could help me here.. I basically tried integrating by parts twice and taking the original negative integral from the second integration by parts to the LHS and then using that to half the RHS and ended up with e^at(sintωt - cosωt)/2, which is different to our lecturers result.
Thanks to anyone for their time!
Could you show us step-by-step what you did??
∫ e^at. sinωt dt
u = e^at, u' = ae^at
v' = sinωt, v = -cosωt
∫ uv' = uv - ∫ u'v
-e^at cosωt - ∫ - ae^at cosωt
-e^at cosωt + ∫ ae^at cosωtnow the second integration by parts,
a = ae^at; a' = a^2 e^at;
b' = cosωt; b = sinωt;
ab - ∫ a'b
ae^at sinωt - ∫ a^2 e^at sinωt
divide everything by a^2
e^at sinωt/a - ∫ e^at sinωt
let original integral = y now - ∫ e^at sinωt = -y
take that to RHS, 2y = e^at sinωt/a
y = e^atsinωt/2aThere is my solution, I can't find where I went wrong so please feel free to point out where I screwed up or if anyone can find the solution and post it I should be able to work it out from there
Forgot to quote
alex282 said:
∫ e^at. sinωt dt
It seems to me that you're forgetting a factor [itex]\omega[/itex] here.
If [itex]v=-\cos\omega t[/itex], then [itex]v^\prime= \omega \sin\omega t[/itex], no??
You made the same mistake in your second integration by parts.
Ahh I get it now. Thanks for pointing that out I should be okay from here (hopefully)
Hi, how about this:
∫eat sinωt dt
u=sinωt du=ωcosωt dt
v=∫eat dt = 1/a eat
∫eat sinωt dt = 1/a eat sinωt - ∫1/a eat ωcosωt dt
∫eat sinωt dt = 1/a eat sinωt - ω/a ∫eat cosωt dt
u=cosωt du= -ωsinωt dt
v=∫eat dt = 1/a eat
∫eat sinωt dt = 1/a eat sinωt - ω/a[ 1/a eat cosωt - ∫-ω/a eat sinωt dt ]
∫eat sinωt dt = 1/a eat sinωt - ω/a[ 1/a eat cosωt + ω/a∫eat sinωt dt ]
∫eat sinωt dt = 1/a eat sinωt - ω/a2 eat cosωt - ω2/a2 ∫eat sinωt dt
∫eat sinωt dt + ω2/a2 ∫eat sinωt dt = 1/a eat sinωt - ω/a2 eat cosωt
a2∫eat sinωt dt + ω2∫eat sinωt dt = aeat sinωt - ωeat cosωt
2 + a2)∫eat sinωt dt = eat(asinωt - ωcosωt)
=> ∫eat sinωt dt = eat(asinωt - ωcosωt) / (ω2 + a2) + C
Ross :)
Yes, that's just great!
ross1219 said:
Hi, how about this:
∫eat sinωt dt
v=∫eat dt = 1/a eat
v=∫eat dt = 1/a eat
Ross :)
Thanks for your solution, I couldn't manage to see where the omega squared came from until I read yours
Great! Glad to help. That was fun. :)
  • · Replies 22 ·
