How Can Maxwell Relations Be Applied to This Thermodynamics Problem?
Lucas Mayr
2. The attempt at a solution
I've tried using the relation Cp = T(dS/dT), isolating "T" for T = Cv2(dT/dS) and using the maxwell relations to reduce the derivatives, reaching, T = Cv2/D (dV/dS), but i don't think this is the right way to do solve this problem, i couldn't find a similar example on the chapter either.
##T## is a state variable that can be thought of as a function of ##v## and ##P##: ##\;T(v,P)##.
Consider ##dT## which will be something times ##dv## plus something times ##dP##. Can you express the coefficients of ##dv## and ##dP## in terms of ##\alpha## and ##\kappa_T##?
Ok, so I've tried looking at dT as a function of both P and v and reached dT = (∂T/∂P)v dP + (∂T/∂v)P dv
And after reducing the derivatives, dT = KT/α dP + 1/vα dv , and using the problem's KT and α.
dT = 1/D dv + Ev2/D dP
dT = 1/D dv + EPava2/(PbD) dP
Tb = Ta + (vb - va)/D + EPava2 Ln(Pb/Pa)/D
which is close but still different from the answer given on the question and i can't find a reason why, what did i miss?
And after reducing the derivatives, dT = KT/α dP + 1/vα dv ,...
Check the sign of the first term on the right. Otherwise, that looks good.
Can you express ##\ln(P_b/P_a)## in terms of ##v_a## and ##v_b##?
