How can we show that u=0?
  • MHB
  • Thread starter mathmari
In summary: Therefore, we have shown that $E'(t) \leq 0$, which implies that $E(t)$ is always non-increasing. Since $E(0) = 0$, this means that $E(t) = 0$ for all $t$. This means that $u_t = 0$, and since $u_t = \frac{\partial}{\partial{t}}(v_1-v_2) = 0$, we have that $v_1-v_2$ is constant with respect to $t
mathmari
MHB
5,049
Hey! :eek:
In my notes there is the following example about the energy method.
We want to show that the problem $$w_{tt}(x, t)-w_{xxtt}(x, t)-w_{xx}(x, t)=f(x, t), 0<x<1, t>0$$
$$w(x, 0)=\phi(x) \\ w_t(x, 0)=\psi(x) \\ w_x(0, t)=h(t), t>0 \\ w_x(1, t)=g(t)$$
has an unique solution.
We suppose that $w_1, w_2$ are two distinct solutions. Then $u=w_1-w_2$ solves the problem :
$$u_{tt}(x, t)-u_{xxtt}(x, t)-u_{xx}(x, t)=0, \, 0<x<1, \, t>0$$
$$u(x, 0)=0 \\ u_t(x, 0)=0 \\ u_x(0, t)=0 \\ u_x(1, t)=0$$
To find the energy we do the following:
$$\int_0^1(u_tu_{tt}-u_tu_{xxtt}-u_tu_{xx})dx=0 \tag 1$$
$$\int_0^1 u_tu_{tt}dx=\int_0^1\frac{1}{2}(u_t^2)_tdx=\frac{d}{dt}\int_0^1 \frac{1}{2}u_t^2dx$$
$$\int_0^1 u_t u_{xxtt}dx=-\int_0^1 u_{tx}u_{xtt}dx+[u_t u_{xtt}]_0^1=-\int_0^1\frac{1}{2}(u_{tx}^2)_tdx$$
$$\int_0^1 u_t u_{xx}dx=-\int_0^1 u_{tx}u_x dx+[u_t u_x]_0^1=-\frac{1}{2} \frac{d}{dt} \int_0^1 u_x^2dx$$
$$(1) \Rightarrow \frac{d}{dt}\int_0^1 \frac{1}{2}u_t^2dx+\frac{d}{dt}\frac{1}{2}\int_0^1 u_{tx}^2dx+\frac{d}{dt} \frac{1}{2} \int_0^1 u_x^2dx=0$$
The energy of the system is $$E(t)=\frac{1}{2}\int_0^1 (u_t^2(x, t)+u_{tx}^2(x, t)+u_{x}^2(x, t))dx$$
$$\Rightarrow E'(t)=\int_0^1 (u_t u_{tt}+u_{tx}u_{xtt}+u_xu_{xy})dx= \dots =0$$
(The energy is always positive.)
$$\Rightarrow 0 \leq E(t) = E(0)=0 \Rightarrow u_t=0 \Rightarrow u(x, t)=u(x, 0)=0 \text{ Contradiction}$$
So, the initial problem has an inuque solution.
________________________________________________________________________________________
I wanted to apply this at the following :
$$v_{tt}(x, t)-v_{xt}(x, t)=f(x, t), x \in \mathbb{R}, t>0 \\ v(x, 0)=g(x), x \in \mathbb{R} \\ v_t(x, 0)=h(x), x \in \mathbb{R}$$
and I have done the following:
We suppose that $v_1, v_2$ are two distinct solutions. Then $u=v_1-v_2$ solve the problem:
$$u_{tt}-u_{xt}=0, x \in \mathbb{R}, t>0 \\ v(x, 0)=0, x \in \mathbb{R} \\ v_t=0, x \in \mathbb{R}$$
In this case since $x\in \mathbb{R}$ we are looking for the characteristic curves to use them as the limits of the integral.
$$u_{tt}-u_{xt}=f $$ The characteristic curves are $$x=x_0 \text{ AND } x+t=x_0+t_0$$
$$\int_{x_0}^{x_0+t_0-t}(u_tu_{tt}-u_tu_{xt})dx=0 \tag 2$$
- $$\int_{x_0}^{x_0+t_0-t}u_tu_{tt}dx=\int_{x_0}^{x_0+t_0-t}\frac{\partial}{\partial{t}}\left (\frac{1}{2}u_t^2\right )dx=\frac{d}{dt}\int_{x_0}^{x_0+t_0-t}\frac{1}{2}u_t^2dx$$
\begin{align}
\int_{x_0}^{x_0+t_0-t}u_tu_{xt}dx &= \int_{x_0}^{x_0+t_0-t}u_t\left [\frac{\partial}{\partial{x}}u_t\right ]dx=[u_t^2]_{x=x_0}^{x_0+t_0-t}-\int_{x_0}^{x_0+t_0-t}u_{xt}u_tdx \\ &\Rightarrow \int_{x_0}^{x_0+t_0-t}u_tu_{xt}dx=\frac{1}{2}\left (u_t^2(x_0+t_0-t, t)-u_t^2(x_0, t)\right )
\end{align}
$$(2) \Rightarrow \frac{d}{dt}\int_{x_0}^{x_0+t_0-t}\frac{1}{2}u_t^2dx-\frac{1}{2}\left (u_t^2(x_0+t_0-t, t)-u_t^2(x_0, t)\right )=0 \\ \Rightarrow \frac{d}{dt}\int_{x_0}^{x_0+t_0-t}\frac{1}{2}u_t^2dx=\frac{1}{2}\left (u_t^2(x_0+t_0-t, t)-u_t^2(x_0, t)\right )$$
The energy of the system is $$E(t)=\int_{x_0}^{x_0+t_0-t}\frac{1}{2}u_t^2dx$$
$$E'(t)=\frac{d}{dt}\int_{x_0}^{x_0+t_0-t}\frac{1}{2}u_t^2dx \Rightarrow E'(t)=\frac{1}{2}\left (u_t^2(x_0+t_0-t, t)-u_t^2(x_0, t)\right )$$
We have also that $E(0)=0, E'(0)=0$, right?? (Wondering)
How could we continue to show that $u=0$ ?? (Wondering) We could show that if we would know that $E'(t) \leq 0$, but how could we get this inequality?? (Wondering)
Hello,
Thank you for sharing your example and asking for further clarification. To continue showing that $u=0$, we can use the energy method to prove that $E'(t) \leq 0$. This can be done by showing that $\frac{d}{dt} \int_{x_0}^{x_0+t_0-t} \frac{1}{2}u_t^2dx \leq 0$.
To do this, we can use the Cauchy-Schwarz inequality, which states that for any two functions $f$ and $g$ on a given interval,
$$\left(\int_a^b f(x)g(x)dx\right)^2 \leq \int_a^b f(x)^2dx \int_a^b g(x)^2dx$$
Applying this to our problem, we have
$$\frac{d}{dt} \int_{x_0}^{x_0+t_0-t} \frac{1}{2}u_t^2dx = \int_{x_0}^{x_0+t_0-t} u_t u_{tt}dx \leq \sqrt{\int_{x_0}^{x_0+t_0-t} u_t^2dx \int_{x_0}^{x_0+t_0-t} u_{tt}^2dx}$$
We can then use the fact that $u_{tt} = f+u_{xt}$ and the fact that $u_t = 0$ on the characteristic curves, to get
$$\frac{d}{dt} \int_{x_0}^{x_0+t_0-t} \frac{1}{2}u_t^2dx \leq \sqrt{\int_{x_0}^{x_0+t_0-t} u_t^2dx \int_{x_0}^{x_0+t_0-t} (f+u_{xt})^2dx}$$
We can then use the fact that $u_t = 0$ and $f$ is bounded, to show that
1. How can we experimentally prove that u=0?
In order to experimentally prove that u=0, we can conduct an experiment where we measure the velocity of an object at different points in time. If the object's velocity remains constant at 0, then we can conclude that u=0.
2. Is there a mathematical equation that can show u=0?
Yes, the mathematical equation for u=0 is u=0. This means that the value of u is equal to 0.
3. Can we use graphs to demonstrate that u=0?
Yes, we can use a graph to demonstrate that u=0. A graph showing a straight horizontal line at the y-axis, with a value of 0, represents u=0.
4. How does the concept of inertia relate to u=0?
Inertia is the tendency of an object to resist changes in its state of motion. In the case of u=0, there is no change in the object's state of motion, meaning that there is no acceleration or change in velocity.
5. Can we use real-life examples to explain u=0?
Yes, there are many real-life examples that can help explain u=0. For instance, a parked car has a velocity of 0, as it is not moving. Similarly, a ball at the top of a hill has a velocity of 0, as it is not moving horizontally despite being at a height.
  • Differential Equations
