seragrefaat
- 3
I want to make a standard iron solution 1 g/L by using iron powder and i can't dissolve it by any way. Is anyone have an idea? thanks in advance.
To create a standard iron solution of 1 g/L using iron powder, the most effective methods discussed include using 6N hydrochloric acid (HCl) or 6N nitric acid (HNO3). HNO3 dissolves iron quickly but must be diluted to prevent passivation. Caution is advised due to the potential for hazardous reactions, including the release of toxic nitrogen oxides (NOx) and the risk of explosions if not handled properly. Electrochemical methods and the use of iron pentacarbonyl are also suggested as alternative approaches for dissolving iron.
PREREQUISITESChemists, laboratory technicians, and anyone involved in preparing standard solutions for spectroscopic analysis or studying metal dissolution processes.
HNO3 dissolves iron quickly, but it doesn't have to be concentrated, you have to dilute it with some water (6N should be ok) or the reaction will be blocked by passivation. Be careful to red smokes of NOx, do it in a hood.seragrefaat said:I want to make a standard iron solution 1 g/L by using iron powder and i can't dissolve it by any way. Is anyone have an idea? thanks in advance.
With an excess of iron it should be possible; it is, with excess zinc and HNO3. However, if NH4NO3 do really reacts in that way with HNO3, it should be, at least, dry.gravenewworld said:Be careful with the nitric acid. I'm wondering if ammonium nitrate is a possible side product if you try to dissolve Fe with nitric acid.
It's quite difficult for me to believe it was only Fe, NH4NO3 and HNO3, are you sure there wasn't something else, even in small amounts, in it?One chemist we had was trying to clean out his glassware of iron residue with nitric acid and caused a massive explosion.
lightarrow said:With an excess of iron it should be possible; it is, with excess zinc and HNO3. However, if NH4NO3 do really reacts in that way with HNO3, it should be, at least, dry. It's quite difficult for me to believe it was only Fe, NH4NO3 and HNO3, are you sure there wasn't something else, even in small amounts, in it?
Mr_Bojingles said:Not trying to hijack your thread I just had a real quick question that isn't worthy or starting a new thread.
Whats the difference between "solvating" and "dissolving"? I read that solvation is also called dissolution. Is dissolution just the process of dissolving? If I add salt to water I would be dissolving the salt in the water. Would I also be solvating the salt in the water or would I be solvating the water with salt?
chemisttree said:What form of iron are you after? Iron(0), iron(II) or iron(III).
gravenewworld said:6 N HCl solution. Use it all the time to clean up flasks with iron residue.
lightarrow said:HNO3 dissolves iron quickly, but it doesn't have to be concentrated, you have to dilute it with some water (6N should be ok) or the reaction will be blocked by passivation. Be careful to red smokes of NOx, do it in a hood.
gravenewworld said:Be careful with the nitric acid. I'm wondering if ammonium nitrate is a possible side product if you try to dissolve Fe with nitric acid. One chemist we had was trying to clean out his glassware of iron residue with nitric acid and caused a massive explosion. Luckily he wasn't hurt, but glass shards went flying everywhere. There were huge 7+ inch shards of glass embedded 8 inches in the wall.
gravenewworld said:We don't know. There could have been some organic material in there as well. ANyway, we aren't allowed to use nitric acid to clean glassware anymore.
lightarrow said:They are completely different cocepts.
"Dissolve" means to bring something in solution, "solvate" means to make the molecules of that compound surrounded by water molecules, bound with some kind of weak bond, as ion-dipole, dipole-dipole bonds.
If you dissolve NaCl in water you will also have solvation of Na+ and Cl- ions, that is every ion in water will react with H2O molecules forming a weak bond with them (with a variable number of water molecules, depending on the kind of ion, concentration, temperature, ecc.).
In general you will always have more or less solvation, even if in some cases it could be so weak that you can neglete it; in that case you could have dissolution but with very little solvation; dissolution is a more complex phenomenon, that includes also solvation, in general (but not necessarily) but also other processes, that is the brokening of the salt's crystal, for example, and the increasing of the entropy due to the mixing solute/solvent.
So, even if "solvation" do certainly affect solubility, it's different from "dissolution".
GCT said:I'm curious to know exactly what is the iron powder that you're employing; how was it obtained? It could be one of the many forms of the hydroxide precipitate. One other way to dissolve iron into the solution is through electrochemistry methods.
Why the need to add HCl? HNO3 alone (not concentrated or Fe would be passivated) dissolves it well.Silex7 said:.. or mix of HNO3 & HCL then heating.. the last one should certainly dissolve it.
