Originally posted by PiRsq
So does R3 have any relationship with the fact that the planets are orbiting in 3 dimension?
No. What we are talking about is a porportional realtionship between the Period of an orbit and its radius.
To show the math:
Force of gravity is
[tex]F_{g}= \frac {GMm}{R^2}[/tex]
M is the mass of the sun in this case, and
m the mass of the planet. The
R² just means that the force falls off by the square of the distance. (double the distance and the force decreases to a quarter of its strength.)
The centripetal force needed to hold the planet in a circular path is
[tex]F_{c} = \frac{mv^2}{R}[/tex]
For a circular orbit, these two forces are equal, so:
[tex]\frac {GMm}{R^2} = \frac{mv^2}{R}[/tex]
m apears in both numerators, so they cancel out, and
R appears in both demoninators, canceling out one
R of
R² which gives you:
[tex]\frac {GMm}{R} = v^2[/tex]
Taking the squareroot of each side gives you the orbital velocity of the Planet:
[tex]\sqrt{ \frac {GMm}{R}} = v[/tex]
In one orbit the planet will travel the circumference of a circle with a radius of
R or:
[tex]C = 2\pi R[/tex]
The time or period of this orbit is equal to distance/velocity or:
[tex]P = \frac{2\pi R}{\sqrt{ \frac {GMm}{R}}}[/tex]
Rearranged:
[tex]P= 2\pi \sqrt{ \frac{R^3}{GM}}[/tex]
Now let's say that you want to compare the periods of two different orbits at different values of
R, then:
[tex]\frac{P_{1}}{P_{2}}<br />
= \frac{ 2\pi \sqrt{ \frac{R_{1}^3}{GM}}}<br />
{ 2\pi \sqrt{ \frac{R_{2}^3}{GM}}}[/tex]
[tex]2\pi[/tex] cancels out:
[tex]\frac{P_{1}}{P_{2}}= \frac{ \sqrt{ \frac{R_{1}^3}{GM}}}{ \sqrt{ \frac{R_{2}^3}{GM}}}[/tex]
The squareroots combine:
[tex]\frac{P_{1}}{P_{2}}=\sqrt{ \frac{ \frac{R_{1}^3}{GM}}{ \frac{R_{2}^3}{GM}}}[/tex]
The [tex]GM[/tex]s drop out:
[tex]\frac{P_{1}}{P_{2}}=\sqrt{ \frac{ R_{1}^3}{ R_{2}^3}}[/tex]
Square both sides:
[tex]\left(\frac{P_{1}}{P_{2}}\right)^2={ \frac{ R_{1}^3}{ R_{2}^3}[/tex]
or
[tex]\frac{P_{1}^2}{P_{2}^2}={ \frac{ R_{1}^3}{ R_{2}^3}[/tex]
Kepler's Third law.
