How did they get these 3 boundaries?
  • Thread starter Thread starter unscientific
5 replies · 2K views · last reply
unscientific
The question is attached in the picture.
From the question I deduced that there are 3 boundaries: red, green and blue.
Blue Boundary
This one is the easiest:
That part of the curve of y2 = 4a(a-x), which corresponds to u = a.
Red Boundary
This corresponds to x = 0, y > 0.
When x = 0,
y2 = 4u2 = 4v2, which corresponds to u = v.
Blue Boundary
This happens when y = 0, x > 0.
When y = 0,
u = 0 or u = x. ------ (1)
v = 0 or v = -x.
Not sure what is going on here...
To try and vizualize the boundaries in the u-v (u,v) plane, I tried to find the intersection between each boundary.
Blue-red Intersection
u = a AND u = v
Therefore, this corresponds to the point (a, a)
I've yet to find the red-green intersection and the blue-green intersection..
I have a better idea..
Instead of going through and trying to formulate each of these piece by piece, try expressing x=x(u,v) and y=y(u,v)
For instance
[itex]y^{2}=4u(u-x)=4v(v+x)\Rightarrow 4(u^2-v^2)-4x(u+v)=0 \Rightarrow (u^2-v^2)=x(u+v)[/itex] so for x>0, and v≠-u≠0, we get [itex]x=u-v[/itex]
Using this, we find
[itex]y^2=4v(v+x)=4v(v+(u-v))=4uv\Rightarrow y=2\sqrt{uv}[/itex] (we can omit the plus or minus, because we are considering y>0.
Blue Boundary
That part of the curve of y2 = 4a(a-x), which corresponds to u = a.Red Boundary
When x = 0,
y2 = 4u2 = 4v2, which corresponds to u = v.Blue Boundary
When y = 0,
v = 0 or v = -x.
You need to recognize that u and v are both non-negative. Then the only way to satisfy ##y^2=4v(v+x)=0## when x>0 is to have v=0.
That is true, but they mentioned nothing about value of u=?
For instance
Using this, we find
I understand that this is also a way to solve it. But sometimes the functions aren't as straightforward as these, so I would like to know the analytical method suggested here..
It's easiest to see what's happening in the figure (Figure 6.1) you posted. If you're on the x-axis and x runs from 0 to 2, what values does u have to go through?
You can throw out the u=0 solution because with it, you won't have any restrictions on the value of x. That is, x can be any value and you'd satisfy both equations. But you need to ensure that x is between 0 and 2 on the bottom boundary.
