How Do Forces Cause Motion?
  • Level: Undergrad
  • Thread starter Thread starter david smith
50 replies · 12K views
david smith
Dear all
When I first learned about forces and motion I was taught F=ma in terms of apply a force to a mass and the acceleration of that mass = x. I was quite clear about how something moved ie apply a force to a mass - it moves or tends to move.
But then I came onto the D' Alembert variation of F-ma=0 ie everything in equilibrium.
Very useful it is too.
In terms of F= ma so ma = F and F-F = 0. So the I thought well how can things move then? I was told by many that the insertion of inertia into the equation so that F-ma = 0 is just a mathematical trick and useful for resolving forces and moments in a mechanical system.
However to me at least inertia is real and easily proved. You can't apply a force unless an equivalent force pushes back.
So I decided that motion is caused by the transfer of kinetic energy of momentum in the direction of the force applied. In terms of conservation of momentum, so that even though there is equal and opposite inertial force there is not equal and opposite momentum and the motion carries on in the direction of the force.
But I can't quite resolve that concept! Since the force applied to the mass does work on the mass as it accelerates therefore (in my mind) the inertial force must do equal and opposite (negative) work to the applied force. As Ek = 1/2mv^2 and work = fd theta and this becomes W = 1/2mv^2theta then Ek of applied force should equal negative Ek of inertial force.
So how do things move??
Can anyone explain? have I got my concepts mixed up?
Thanks Dave Smith
A rock climber can ascend narrow chimneys using a standard method. The climber can even rest in place partially up the chimney. At rest, the climber is in equilibrium. Does that mean when at rest, there are no forces?
Hi Dave, welcome to PF. One serious problem is that your terms "kinetic energy of momentum" and "Ek of applied force" are very difficult to understand. Energy, momentum, and force are all very different, and you probably would not say something like "length of temperature" or "height of voltage."
To use your example, when A accelerates B, it does work on B and increases B's energy. The energy of A is decreased, so we could say that B does an equal amount of work on A, except opposite in sign. (I find the term "negative work" confusing.) So total energy remains constant. I'm not sure why you think you can set the two values (one positive, one negative) equal to each other ("Ek of applied force should equal negative Ek of inertial force.")
Edit: Oh, I think I see what you meant. Is it that the energy change in B is, say, 5 J; the energy change in A is -5 J; and 5 = -(-5)?
Andy
Yes there are forces at work and they are in equilibrium
Dave
Mapes
Its quite possible I am getting confused here but, I can't imagine a way length an temperature are linked however energy and momentum and force: Kinetic energy = 1/2 mv^2 and momentum = mv so kinetic energy requires momentum. The applied force does not exist on its own it requires a mass + an acceleration so acceleration = d/t^2 or a change in momentum so force = mass * change in momentum. Therefore a force = change of momentum = change in Kinetic energy. And so, in my mind, I can (perhaps loosely) say the energy of momentum and the Ek of force.
So how do you explain motion in terms of change from a state of rest or constant velocity.
I get that, so are you saying the forces are equal and it is the exchange of energy that causes motion?
I don't require a definition as I think I know all the definitions. Don't get me wrong I can and do work with all the equations of Newtonian mechanics (even if the above doesn't sound like it). I just suspend my disbelief and do the maths.
Thanks for your help, Dave Smith
David,
Let me back up: there's a couple of places you say something like "the origin of an applied force is the acceleration of some object". Is that what you mean?
Andy Resnick said:
David,
Andy
Yes both, if there is a force there must be an acceleration (or tendency to acelerate) and you can't apply a force unless you have another force to resist it ie 2 accelerations in opposite directions. EG you can't jump in the air if you don't have the ground to push off.
Cheers Dave
Ah. Now I understand your confusion.
The formula F = ma (or F = dp/dt) is, for various reasons, very subtle. First, it's important to realize that we never measure forces. There's no such thing as a 'force-o-meter'. This is not the case for acceleration (or velocity, or position)- we have rulers and stopwatches to measure these things.
There may be objections to this- surely a spring measures force? Or a strain gauge? Or a pressure gauge? None of those things really do, they rely on constitutive (material properties) relationships which relate a force (dynamic quantity) to a displacement (kinematic quantity).
F=ma conceals this important point- it sets equal a *kinematic* quantity (acceleration), with a *dynamic* quantity (force). We do not ultimately know what causes a force. We have lots of models, to be sure, in as much detail and complexity as you can stomach. But in the end, we still have no force-o-meter.
If you like, you may think of 'mass' as being a constant of proportionality between an applied force (whatever the origin of said force) and a resultant motion- but that has limits as well (massless particles). Consequently, it may be helpful to spend time temporarily expunging 'force' from your mental concepts and instead think in terms of momentum and energy.
I didn't read the entire thread, but I'm not seeing in the first half of the OP anything to be misunderstood. f=ma means f=ma. Both forces are represented in the equation: the left side is the force applied to the object and the right side is the equal and opposite force applied back.
Re-arranging the equation to f-ma=0 doesn't change anything. 0 isn't the acceleration, it is the sum of the forces.
But then you repeat your question without actually connecting it to the math you just showed, so it isn't clear what you don't like about this.
Anyway, though, by throwing energy in there in the second half of the post, you are just confusing yourself. If you ever do sort out the math of it, you'll find it just reduces back to f=ma anyway. So just drop that entire thing and just get your arms around the idea that f=ma is a true and complete statement of how a force results in acceleration.
Hmm, maybe this will help. In order to apply a force to an object and not have it move, you need two force pairs on it, not one. If you have an object bolted to the ground and you push on it, you and the object exchange a force and the object and the bolt exchange a force. The forces sum to zero, with two positive and two negative.
If you have only one force pair, one of those forces manifests itself as ma in order to maintain the balance. If you start with F1=F2 and know that there is no corresponding force pair to stop the acceleration, then F2 must be a force due to inertia and acceleration. F2=ma.
Physicists often treat gravity as equivalent to acceleration, so the same principle applies to the unmoving climber on the side of the mountan. The force pair between the climber and mountain is F1=F2 and F2 still equals ma.
I enjoyed reading Andy's answer. As supplement, Greenwood says this in Principles of Dynamics:
"The concept of force as a fundamental quantity in the study of mechanics has been criticized by various scientists and philosophers of science from shortly after Newton's enunciation of the laws of motion until the present time. Briefly, the idea of a force, and a field force in particular [Greenwood defines field forces as those involved with action at a distance], was considered to be an intellectual construction which has no real existence. It is merely another name for the product of mass and acceleration which occurs in the mathematics of solving a problem. Furthermore, the idea of force as a cause of motion should be discarded since the assumed cause and effect relationships cannot be proved." (boldface mine)
Equal and opposite forces when an object is accelerated.
Reaction forces are the result of acceleration times inertia (inertia equals mass in the case of translational acceleration). For angular movement, you have reaction torque = angular acceleration times angular inertia. Reaction forces or torques don't stop acceleration, they are the response to acceleration. Without acceleration, reaction forces or torques don't exist.
When calculating accelerations, reaction forces are not included.
Say a pushing force is applied to a block on a frictionless surface, the block accelerates according to the equation, A = F/M. The block has inertia, and resists acceleration with an equal and opposite "reaction" force that exactly equals the force that is producing the acceleration (F = MA) but this determines the rate of acceleration, it doesn't cancel the acceleration.
Close enough for me. If the object involved has a known stress / strain curve, then the change in length of the object under tension or compression could measured be used to calculate force. Tension could be measured by the vibration rate, for example the strings on a piano or guitar, higher tension => higher pitch.
The D'almebert "force" is not a real force, you treat ma as if it were a force - but its not..
I enjoyed reading this post, nice.
Jeff Reid said:
<snip>
Yes, but do you see what you did? You switched from talking about 'force' (Newton) to STRESS (Cauchy).
IMHO, Cauchy's first law is much more relevant that Newton's second law, for this very reason. We can indeed measure stress- pressure and strain gauges. This is not measuring a force! Applying a Newtonian force to a pressure gauge will give different results, depending on the geometry of the pressure gauge.
All, Russ, Jeff, Mapes, Andy, Cyrus, thakyou for you time and effort and your input.
Aha! this is more like it, these are the types of answers I've been looking for.:approve:
Let me explain, I work as a Podiatrist and deal with pathological problems of gait and posture in terms of biomechanics. Therefore I am dealing with kinetics and kinematics -forces and movement.
In my degree we were always taught that 'forces and moments in a mechanical system , whether stationary or in motion,are always in equilibrium' IE D'Alemberts version of Newtons law F=ma => F-ma=0.
(Russ
- I know zero is in terms of balance of forces and moments and not acceleration.)
So my quandry has always been if the forces and moments are equal on each side of the equation how can there be motion?
The usual answer are:
1A: Just accept it :rolleyes: (My reply: Can't) Russ wrote-
Maybe I should Russ but isn't it a complete statement of how we explain acceleration in terms of force?
Russ
If you have only one force pair, one of those forces manifests itself as ma in order to maintain the balance. If you start with F1=F2 and know that there is no corresponding force pair to stop the acceleration, then F2 must be a force due to inertia and acceleration. F2=ma. Physicists often treat gravity as equivalent to acceleration, so the same principle applies to the unmoving climber on the side of the mountan. The force pair between the climber and mountain is F1=F2 and F2 still equals ma.
confused! - so are you agreeing with me then, ie that forces are always in equilibrium and do not cause motion??:rolleyes:
2A: Inertia is an imaginary force, Cyrus wrote-
(My reply: seems real enough to me -EG try punching a wrecking ball hanging by its chain and see how the inertial force breaks your hand:cry:)
So there is inertia and there are reaction FORCES
Jeff
Oh! so there aren't any reaction forces, which is it? Is it valid (even if useful) to ignore a parameter just for convenience?
Jeff
Exactly! so therefore if the forces can't cause the acceleration, what does? (by your argument one ignores the inertial forces when calculating the acceleration, so then there is the inertia of the negative acceleration of the mass applying a force and the force of inertia of the positive acceleration of the mass resisting the applied force. Ignore the inertial forces, which is both sides of the equation ma = ma, and you get acceleration. How?
3A: Don't mix force theory with energetics theory. (My reply: Why?, isn't momentum and energy transfer directlly related to force? You can't transfer kinetic energy without applying a force and potential energy only becomes kinetic with the application of a force.)
I'm definintely confused.!
Difficult, but you may be right.
Good concept? :approve:
Not so difficult now, if I intuitively consider your premise above.:cool:
Can yougive some references please Mapes:devil:
By this premise and Andy's above my question becomes a mute point. "considered to be an intellectual construction which has no real existence". If force is a construct for, or a byproduct of, the calculation of other parameters of kinematics, then force is imaginary and cannot cause motion. So what does?
Mapes
Tell me more, Tell me more! Please Please!:biggrin:
This is all good for me
Russ
Re reading this I see what you are staying (i think) So if I push against someone who is pushing back we each have Inertial forces (1 pair) and apllied forces (2 pair). Remove one of the applied force and we have motion. This means we have unbalanced forces and so one inertial force must accelerate to give us the balanced equation. Hmmm! Have I got that right. Not heard that concept before, I'll have to think about that one
Cheers all Dave
david smith said:
Dear all
Thanks Dave Smith
F is an external force on the object, ma is not an external force...
This is your problem, you are simply looking at F-ma=0 and saying, it equals zero, so it must be in equilibrium. But now you are assuming there is some OTHER m'a'=0.
in other words,
F-ma=0=m'a'
and concluding this a'=0, and therefore it does not move. You have imposed a m'a' term to satisfy a FALSE NOTION you made up in your head that it must stay at rest. There is no such, m'a' =0.
The fact is F-ma=0. This does NOT mean a=0! Very important you realize this. THIS a, is the acceleration, and it is NOT zero. This a' term I made up is just that, something YOU made up without realizing, its not equal to zero, and infact it does not even exist.
Are you a biomedical engineer?? I'm a mechanical engineer and our concepts of this should be identical.
1A: Just accept it :rolleyes: (My reply: Can't) Russ wrote- Maybe I should Russ but isn't it a complete statement of how we explain acceleration in terms of force?
Physicists may see this differently, but I see this as a needless complication of something that can mathematically be reduced to f=ma anyway.
No, the forces are in equilibrium which means there must be motion. The equilibrium (the reaction force) is provided by ma. If you didn't have F2=ma in the equation and you applied a force of, say, 1N, you'd have 1-0=0 for F1-F2=0 -- an untrue statement.
[cyrus was basically saying the same thing]
Reaction forces are the result of acceleration, they are real, but they are not used to calculate acceleration. Acceleration = force (or torque) divided by inertia, and reaction forces aren't included in this acceleration equation.
Ok so thanks for your tenacity in staying with me, I expect some have lost the will to live with this question:smile:
Most agree with that, Good!
in other words,
F-ma=0=m'a'
and then Russ added
AaaaaH! Light going on, small epiphamy
So if I read F=ma is the same as ma = ma then mass * acceleration of one object is equal to the mass * acceleration of another object acting on it, then, without considering ma as a force (as suggested by Andy) this makes sense. OK! Hooray!
Can I say then that:
Force is a useful intuitive construct of ma and is not necessarily real. F=ma indicates force is correlative with acceleration of a body but not necessarily causative.
So to me this looks like conservation of momentum ie change in momentum1 (inversely)= change in momentum2, (assuming no losses) is it?
So can I say that a change in momentum = a transfer of energy?
Can I also say change in momentum1 = change in momentum2 in the direction of the force applied?
Therefore could I make the statement that:
Movement is due to transfer of energy from one body to another and in the direction of the force applied.
Much appreciated Dave Smith
<snip>
Cheers all Dave
Consider this simple action: standing still while raising one arm up. It's clear that there are local unbalanced forces from the unapposed muscle contracting, causing the bones to pivot around joints, etc. What may be less clear is that in order to remain standing still during this, there are also unbalanced forces distributed through the entire skeleton, causing small shifts in balance and ultimately, weight distribution on the feet.
So far so good? Now think about what would happen if an astronaut did the same thing. Because there's no opposing force at his feet (from being up in space an in a microgravity environment), the astronaut's body must conserve momentum. So, as (s)he raises the arm, the entire body is likely to be set into rotation to ensure that the center of mass remains stationary.
Is that helpful?
Hi David, I think you are getting some basic concepts mixed up.
In what sense does this imply any kind of equilibrium? Usually equilibrium is defined as a=0 which does not follow from F-ma=0.
And further 0=0. In general you can reduce any equation to the trivial 0=0. That doesn't imply anything whatsoever about the original relationship other than that it was true (algebraically).
You most certainly cannot.
I'm not quite sure what you mean there. You can have a force without an acceleration, but you cannot have an acceleration without a force. If there is an acceleration, force is the cause.
[snip] Can I also say change in momentum1 = change in momentum2 in the direction of the force applied?
I'm not sure why the word "inverseley" is in there, but the change in momentum 1 is equal to the change in momentum 2 (the second statement is true). Remember, velocity is a vector.
No, momentum and energy are not the same thing. A transfer of or the consumption of energy does not necessarily imply a change in momentum.
No, you cannot. A change in momentum does not imply a transfer of energy. Consider an orbit. Two bodies are constantly applying forces to each other and being accelerated by each other, yet there is no change in kinetic or potential energy.
You're going back to the idea in your original post, so let's revisit something else (same issue, really):
As was already stated, that's just word salad. It doesn't actually mean anything. Kinetic energy and momentum are two different things. There is no such thing as "kinetic energy of momentum".
Russ
Thanks for your help Russ and all, I guess I'll just have to learn to accept what I was taught and accept defeat on this eh!
All the best Dave
I think the issue here is that although reaction forces peform work, it doesn't mean that acceleration doesn't occur.
Take the simple case where a spring accelerates a block on a frictionless surface. The integral of force times distance supplied by the spring equals the work done and the increase in kinetic energy of the block. At the same time, the potential energy of the spring has gone to zero. So the springs force increased the kinetic energy of the block, and the blocks reaction force reduced the potential energy of the spring to zero. So potential energy in the spring was converted into kinetic energy of the block. The spring peformed work on the block and the block peformed (negative) work on the spring, resulting in the block being accelerated to some specific speed, and the spring ending up with zero potential energy.
Or in the case of a 100% elastic head on collision between a moving body and a stationary body, both with equal masses. During the dwell time of the collsion, the force from the moving body accelerates the staionary body, while the reactive force of the stationary body decelerates the moving body to zero velocity.
For another example, take the case of a car accelerating (ignoring aerodynamic drag). The car's tires push back on the pavement, which creates a very small amount of angular acceleration of the earth. The reaction force from the pavement results in the forwards acceleration of the car, which has a much smaller mass and gains most of the kinetic energy. (Note that angular momentum of the Earth and car (consider the car to be in low orbit) remain constant.)
As another example, take the case of a rocket in outer space. The rocket engine accelerates spent fuel up to a high rate of speed in one direction, and the reaction force from the fuel accelerates the rocket in the other direction.
I'm not sure how to describe reaction forces in cases like gravity, where there are equal and opposite attactive forces, and it's not clear to me if either of these forces could be considered to be a reactive force.
Dale
=DaleSpam;1639357]Hi David, I think you are getting some basic concepts mixed up.In what sense does this imply any kind of equilibrium? Usually equilibrium is defined as a=0 which does not follow from F-ma=0.
Applied force + inertial force = 0 inertial force being equal and opposite to applied force
I don't agree with the 2nd part, not that that means much:rolleyes: but here are some references that have a different view.
Cheers Dave
Then that is the key. This definition of equilibrium does not mean a=0, which is the usual definition. In fact, this definition of equilibrium does not imply anything about the motion of the body under consideration. IMO, this is a completely useless concept of equilibrium since it is always true and does not simplify the problem.
Yes, and from the first paragraph of the first reference:
Many people believe that D’Alembert’s approach to mechanics, an alternative to the momentum balance approach, should not be taught at this level. Students attempting to use D’Alembert methods make frequent mistakes. We do not advise the use of D’Alembert mechanics for first-time dynamics students.
You are demonstrating exactly why they included this caution as the initial paragraph. My recommendation is to use standard analysis techniques and the standard definition of equilibrium. You obviously are getting confused by this approach which adds nothing of value that I can see until you get into Lagrangian mechanics.
Jeff wrote
Jeff Reid;1639820]I think the issue here is that although reaction forces perform work, it doesn't mean that acceleration doesn't occur.
Agreed
Jeff
Jeff are you saying that it can?
Agreed, so that's change of momentum 1 = change of mometum2 isn't it?
As we are carrying on this discussion (much to my delight) can you explain what
Russ wrote IE
and so
"There is no such thing as "kinetic energy of momentum".
Kinetic energy is 1/2mv^2 (scalar) and momentum (vector) is mv (p=mv)so by increasing the momentum the kinetic energy is increased (isn't it?)
The standard unit of energy is the Joule, such that 1 Joule is equal to the work done by a force of 1 Newton in moving a distance of 1 metre - in the direction of the force.
So that energy is scalar but in terms of a vector ie force.
The unit of momentum is kgm/s + direction so clearly eergy and mometum are not the same but
Is Russ saying energy is the ability to do work F*d but momentum p=mv does no work since there is no force involved so energy can't be equated to momentum.
But doesn't a body with momentum have the ability to do work?
When a body with momentum acts on a stationary mass doesn't the energy transfer from one body to the other to conserve momentum and so there is motion of the second body, which now has momentum. In the interaction of the two boies there were forces and accelerations. So aren't all these directly conected and dependent on each other?
Is this what jeff is saying?
Jeff
Not quite sure what you are trying to say here?
Cheers Dave
Dale, you are right in many ways. However I have no problems with the maths, at the level which I work. (which is low compared to you physicists) One can manipulate an expression or group of expresion by precicely applying the rules of algebra and get a correct outcome without understanding any concepts. I'm just trying to get a better understanding of the concepts. I regularly use the form of this - that = 0 in my work, papers and thesis, and find it more useful than this = that * something.
I question my understanding of the concepts when someone says something like
" it is the plantarflexion moments about the ankle joint that lift the heel and not the velocity of the Centre of mass moving about joint.
So are they are saying it is not the momentum of the body that carries you forward, when moving forward necessitates the ankle plantarflexion and heel lift to raise the CoM and increase its potential energy for use in the next step.
I have to have an explore of my understanding of principles. and so I have with all your help. For which I am most grateful.
Cheers Dave
Cheers Dave
